View Poll Results: Which combo should I use?
5.7LS1/4L60E 4 36.36%
6.0LQ/4L60E 5 45.45%
Keep Goodwrench350TPI/700R4 2 18.18%
Voters: 11. You may not vote on this poll
Old 01-29-2004, 02:31 AM   #6
chevy blazer guy
I have a 205 behind a 4l80e and it was actulaly pretty easy to do. The bolt pattern on the back of them is the same as a th400 so you can use the transfer case adapter for a th400 on them. The only thing you have to do is machine 1/16 of an inch off the the ring on the adapter that sticks in the back of the transmission. You just need the right lengh input shaft for the 205.
chevy blazer guy is offline   Reply With Quote
