Old 01-22-2015, 08:27 AM   #7
Re: Possible sabotage?!
Is it 4wd? I've known transfer cases to overfill with fluid from the transmission due to a bad seal. I can understand how that happens since the transmission is pressurized. Not sure if the fluid could seep back to the transmission when vehicle sits. I guess it would be more likely if the vehicle is parked with the front end lower than the rear (gravity)
