"brake cleaner"
i got the diff.cover off my axle,i want to clean all the sludge before i re-bolt it.will brake cleaner work fine?or should i use somthing special for that? thanks befor hand.
Re: "brake cleaner"
Yes
Senior Enthusiast
Re: "brake cleaner"
Brake cleaner works great and leaves no residue, but be careful. That stuff is deadly dangerous to ingest the fumes so work outside if you can and wear a respirator. That's one item where the warning labels should really be read before use.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
Re: "brake cleaner"
thanks sprinter and yes thank you markebo1
#5 | |
Re: "brake cleaner"
http://www.brewracingframes.com/safe...sgene-gas.html |
Re: "brake cleaner"
it wont kill you right away it takes a few decades
. there's a reason it's called "parkinson in a can" . it seems like alot old wrenches or having issues like Liver and or bladder Cancer.! It's not about you. It's about the suffering of the one's that love you that is the issue If you become ill . and this coming from a guy who chewed alot of paint chip as a kid and drank alot of gasoline via garden hose......sp . .
My Spelling is Not Incorrect...It's 'Creative' . . 1966 C-20 .....Swap 91 G-30(5.7 FI)/4L80E http://67-72chevytrucks.com/vboard/s...d.php?t=789617 59 Viking Revival .. http://67-72chevytrucks.com/vboard/s...d.php?t=632341 |
60-66 Nut
Re: "brake cleaner"
Another option would be to go to Home Depot and get a gallon of mineral spirits and a couple cheap brushes. For some cleaning uses I prefer carb cleaner over brake clean. Of course you guys in California can't get the good stuff that the rest of us can.
![]() Join Date: Apr 2009
Re: "brake cleaner"
Don't Spray Pinion Seal It will eat the Gasket Rubber
1966 GMC K25 V6 351E Original Utility Truck 2000 C3500 Hot Rod Utility Truck 2003 ROAD KING 100th 124ci 6 Speed 145CI M/P Pro Street FXR 2002 FXDP 2007 2500HD DURAMAX. DD Studio Teamsters / Mechanic Retired GM Master Tech 20 Years Retired Ford Tech 15 Years |
Re: "brake cleaner"
if you are working for someone else and they are paying for the brake clean go ahead and use that. lots of it. if you are paying for it - use mineral spirits
