01-20-2015, 08:33 PM | #1 |
Booster to master cylinder push rod adjustment
My booster to master cylinder push rod was too long by approx 1/8 - 3/16". After adjusting it I know it's close to where it needs to be now, but what's the correct tolerance? Obviously its bad to have forward pressure on the m/c piston, but I'm assuming you don't want too much play either. Any tricks to get it just right? Thx!
1967 Chevy C-10, 250 L6, Powerglide, 3.73, SWB, Fleetside Upgrades: Power steering, Offset air cleaner, Rear Sport bumper, 3 point safety belts, HEI, -1/-2 springs, 16x5 wheels, McGaughy's disc brake conversion, Sway bar |
01-20-2015, 10:05 PM | #2 |
Re: Booster to master cylinder push rod adjustment
watching....I had issues with mine too........
I did finally get it adjusted to where it works but want to see what the pros say.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11. 1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9 |
01-21-2015, 10:44 AM | #3 |
I had the same problem. Put it on the grinder. Gave myself 1/16 or 1/8" clearance, forget which. No problems and my brakes work great.
70 GMC K2500 82 GMC K3500 09 GMC 2500HD 4x4 |
01-21-2015, 02:28 PM | #4 |
I have a disk master cyl on a drum booster. I know tha'ts where my problem is.
What I had to do was... Find out how short to make the push rod by removing the adjust tip. Then placed a blob of my daughter's modeling clay in the bore of the MC. Measured how much space there was when all was bolted together. I unbolted the MC and measured the thickness of the clay. Then I had to grind off the front end of the MC push rod a bit shorter than the push rod with the tip installed. Drill and tap the end of the push rod until the correct assembled length was about 1/32" too short. Then adjust the front end of the push rod until all worked happily. I guess I could have gone to AutoZone and bought the correct unit for $149 and put it all back quickly.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11. 1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9 Last edited by Longhorn 70; 01-21-2015 at 02:34 PM. |
01-21-2015, 02:45 PM | #5 |
This booster was originally mated to a drum m/c also. Fortunately, it's adjustable, so shortening isn't difficult. I'm just trying to figure out what the correct clearance is supposed to be. I guess I'll just get it to where it barely touches or as little clearance as possible. Clay is a good idea. Thx!
01-22-2015, 11:35 AM | #6 |
1/4" based on this. I was just reading it a couple days ago because I put in a Disc Drum MC with a prop valve. Now I'm having rear lock up problems. Anyhow scroll down in this doc it's a good doc from cpp.
http://www.classicperform.com/TechBo...oubleshoot.htm
White K20 |
