69 maroon interior
Hi - new to the board.
Starting to work on the 69 GMC that I have owned for the past 27 years. It appears that this was the only year that maroon was used on the interior. Brothers and LMC do not seem to stock the dash pad or arm rests in this color. I would like to go back original. Is dying a suitable option? Other suggestions? Any input is appreciated. ![]() |
Re: 69 maroon interior
Exterior pic.
The two-tone maroon and red looks nice. Here are some pictures to get you going. Dyeing might be the easiest route. I have the Ditzler paint codes for the maroon trim color and the flat upper dash paint if they would help any. Did some research when I was looking at a 69 CST in maroon with the red/maroon interior (first picture). The second is a good overall picture and the rest are of another very nice 69 I have several more pictures of if they would help.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
![]() Join Date: Feb 2014
Tim,
I would like the maroon paint code as well. Thank you, Bruce |
Here is a clip from the Ditzler 69 Chevrolet/GMC truck chart.
http://www.autocolorlibrary.com/ Also a lot of nice pictures can be found at these two links of a nice 69 K2500 with a maroon interior and worth grabbing as a reference. http://www.ebay.com/itm/GMC-Other-KM...-/281441885542 http://www.ebay.com/itm/GMC-Other-KM...-/390948479117
The 69 GMC on ebay is an excellent reference and one of my favorite color combos. Thank you for the paint info. Take care, Bruce
The maroon interior is my favorite. It is not as rare as the dark blue (69 only) and most of it can be found with patience. The hardest piece will be the dash pad and mirror mount cover. For some reason they are always cracked or missing. Horn buttons exist - even a few NOS pieces are out there.
Bucket seat and consoles are out there but those who have them hoard them...apparently ![]() I have been collecting maroon, dark blue, and now 70 only gold. Good luck on your hunt! Spartan
'69 K20 350/4 speed/Rockwell/D44/HO52. "orange rhymes with door hinge" |
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
Here are some pics from a 69 CST I had. I added the pic of the buckets for info. When I had the truck a board member sent me pics of the buckets in the dark maroon.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
Cool color. Never seen one in person.
That Ditzler color sheet isn't the most accurate for interior parts. The "seat separator" is listed as body color for Dk Blu trucks, but it wasn't from the factory (it was injection molded in some kind of blue plastic - body color is close enough for wholesale replacement but it wasn't "right"). If you're going to shoot plastics, particularly dashboards that might have seen silicon or armor-all in their lifetime, prep is key. I would go to an autobody shop and grab the right prep. For PPG they have a one-time-use expensive sponge with a scrubber on one side and chemical prep impregnated into the sponge. I've used it and had great results. I generally shoot a coat of adhesion-promoter too. That's just rattle can. You probably then need three steps - primer, base, clear. I think semi-flat like 'Fixed'n'Flat' looks good. By the time you're done buying supplies you MIGHT be able to get it done at "Just Dashes" cheaper if you're not doing other interior parts too. Edit: remember each coat will "sink" your grain a little. If you get too thick the vinyl grain doesn't show up as well. I guess light coats?
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
Thanks guys for the good info and pictures. Nice inspiration and quite a lot to digest. Leaning toward purchasing white replacement parts and dying /painting. I will keep you posted.
White to maroon is a big jump. I'd recommend starting with red parts then darkening them with dye until they match.
I have seen those buckets. Nice. I think he's got the console too.
Hope he decides to sell someday. I'm game ![]() I have buddies for the current build. They will be covered in maroon before long. Dark blue buckets and console in that condition would be sharp too IMHO. Cheers Spartan
I have made some progress. New dash,arm rests, radio, heater controls, steering wheel and seat. Need a second job to keep up!
Napa vinyl maroon paint met the need. |
From the other side.
#15 |
![]() Join Date: Sep 2007
isint this the same maroon used in 67 also? both my trucks have had red interior. and yes that dash is hard to find.
my 67 is actually orange but the manufacturer painted the top of my dash red to match the dash pad and the vents. funny huh?
1967custom |
#16 |
![]() Join Date: Dec 1999
Dashes Direct use to offer a maroon dash pad.
#17 |
Junior Member
![]() Join Date: Dec 2010
My '69 CST is that medium red exterior with the dark red interior like the last few pictures SS Tim posted. Never liked the color combination but I also didn't realize that interior was a '69 only option. Pretty cool info. Thanks y'all.
1969 CST-10 - "Glory Bound" - build in process (slow going) 1971 Cheyenne 10 2006 GMC Yukon XL Denali Isaiah 46:4 - I will be your God through all your lifetime, yes, even when your hair is white with age. I made you and I will care for you. I will carry you along and be your Savior. |
#18 |
1971 GMC C2500 - 350 SB - 700R4 1972 Chevy C10 - 350 SB - TH350 |
