Mini-Starter Issues?
I know this is a long shot, but thought I would see if anyone has had the problem that I'm encountering. I bought a Summit mini-starter for my big block in my 1970. The headers that are on the truck, I bought used, so I don't recall the brand but they were either Hooker or Hedman, long tubes that were bought originally for a square body. The oem style starter fit fine, but the mini-starter will not. It is a clockable, linear bolt pattern starter. It seems that since the starter is shorter, the solenoid is closer to the flywheel and hits the block. If I rotate it, the body of the starter hits the headers. Has anyone come across this before? Ill try to get pics tomorrow morning if itll help.
-Scott- 1970 C10 shortbed 396 1969 C30 dually flatbed "Vidalia" |
#2 | |
Re: Mini-Starter Issues?
So is the description wrong? The Summit 829000 starter is listed as fitting 153 and 168 tooth ring gears in big and small block applications. I'm thinking of just machining a new nose piece that will rotate the solenoid downward (toward the ground) and it should clear and I'll have easier access to the wires. Any reason this wouldn't work? Thanks for the response Fitz.
EDIT: I guess if it doesn't mesh with the 168, it won't work anyway.
#5 | |
If you want to go through the trouble of machining the nosepiece and turning the solenoid, go ahead, but when you are done machining that, you will have to machine the face that mounts against the block until the pinion shaft with the pinion retracted into the nosepiece is 0.125 plus or minus 0.005 inches from the ring gear for it to mesh. That is how the starter supplied by GM with my 572 fit, and when it failed I bought 5 starters before I wised up and called Delco. They gave me the housing type (PG260) and then I found a starter that would work on that motor. All in all, a very frustrating experience. I don't mind working on my truck but I spent the better part of two months polishing the shop floor with the back of my shirt trying to get that fixed! It's not hard if you have a lift but changing a starter a dozen times with the truck on jackstands is not my idea of fun. |
![]() Join Date: Jun 2014
I just had this same starter SUM-829000 and it worked for a whopping month or less!! It just almost left me stranded the other night and I had to beat it with a hammer to get myself home....I went and bought an Autozone starter with a lifetime warranty that fits a 1995 Chevrolet Caprice 5.7 (and other models I'm sure).....this one works for me because I have a 153 tooth flywheel.....my engine isn't the original engine....it's the 350 / 330 HP with Vortec heads.
The starter off a 1996 Silverado would work for the 168 tooth.....they are gear reduction starters and work great. Anyways.....this summit starter is on it's way back now for a refund. It got good ratings overall, but if you look at the bad ratings....a lot of people say it just quit working on them as it did on me. Also I did notice that even with my stock ramhorn manifolds the summit starter was about 1/2 an inch away from my exhaust pipe which could of caused some heat soak issues later.....the new Autozone starter is much further away from the pipe now.
1972 Chevrolet C20 Cheyenne Custom Camper LWB - 350 / 330 HP GM Crate - TH350 / Mild Shift Kit - Dark Blue / Medium Blue - Paint Code 559 |
Thanks for the info guys. It's too late to return mine because i had already "modified" the nose piece. I went ahead and made a complete new nosepiece that rotated the starter to be solenoid down and allowed me more room away from the ring gear and with shims I should be able to get it pretty close. If not, I'll be getting the '96 silverado starter if it'll fit with my long tube headers. Isn't it roughly the same size as the old gm starters, just gear reduced?
#8 | |
Well let me rephrase that. I'm not sure if the caprice starter is smaller but it for some reason is much further away from my exhaust pipe than the summit starter
Old member
STOP:
Before you buy a starter look at this thread I posted about 4 years ago.The starter was still working when I sold the 305 and swapped in the LS motor. I never had a minutes trouble out of it and that was a lot of hot starts. ![]() http://67-72chevytrucks.com/vboard/s....php?p=4151565
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#11 | |
