Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 01-22-2015, 09:09 PM   #251
IronCanine
I'm trying....
IronCanine's Avatar
Re: 70 Blazer Frame Off
First coat of primer going on....neat to see it all one color for the first time in a long time.
IronCanine is offline   Reply With Quote
Old 01-22-2015, 09:20 PM   #252
smbrouss70
smbrouss70's Avatar
Awesome!
You know for some reason, I am really drawn to your build, even though I don't usually get into the 4x4's. I can't keep my eyes off of it though.
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 01-22-2015, 09:27 PM   #253
IronCanine
I'm trying....
IronCanine's Avatar
Originally Posted by smbrouss70 View Post
Awesome!
Thanks....it's because our trucks are bros...70 St. Louis Blazers separated at birth. I'm sure if my truck needed a kidney or a bone marrow transplant, your truck would be the perfect match. Luckily those were the only two things that were good on my truck...so you're safe.
Old 01-26-2015, 09:14 PM   #254
OLDYELLOW
OLDYELLOW's Avatar
Looking good. Can't wait to see some more color on it. Have you thought about what you are going to paint the top with?
OLDYELLOW is offline   Reply With Quote
Old 01-26-2015, 09:31 PM   #255
IronCanine
I'm trying....
IronCanine's Avatar
Thanks. Don't know about the top yet. We're still considering several options documented previously on the board...but mainly it's Zolatone vs. a bedliner of some sort. There are a few really good top repair/repaint threads on the board that have made different techniques work...we've still got a little time to sort it. No doubt I'll post it as soon as we figure it out for sure.
Old 01-27-2015, 01:29 AM   #256
72K5CSTDarkOlive
72K5CSTDarkOlive's Avatar
The speed of this build amazing! Keep it up
My Build Thread 72 K5 http://67-72chevytrucks.com/vboard/s...d.php?t=628612
Build version 2.0: 72 K5
6.0 LQ9, 4L80e, NP205
http://67-72chevytrucks.com/vboard/s...d.php?t=793192
1972 CST K5 Blazer Dark Olive
72K5CSTDarkOlive is offline   Reply With Quote
Old 01-27-2015, 10:20 AM   #257
IronCanine
I'm trying....
IronCanine's Avatar
Thanks Mike. I guess it has been pretty quick...but nothing ever seems that way when you're in it. No new pics since she's in her 50 Shades of Gray period. Primer, guide coat, wet sand, repeat.
Old 01-27-2015, 04:54 PM   #258
72K5CSTDarkOlive
I have someone doing my body and paint work and you're way ahead of me still. If I attempted my own paint and body I would be looking at 2018 to complete it lol
Old 01-27-2015, 05:13 PM   #259
IronCanine
I'm trying....
IronCanine's Avatar
Don't be fooled Mike...I'm not doing my paint and body either. If you go to the first page of this build thread there's a red Nova convertible on there. The guy who painted that is doing this. It's his shop and he let's me wrench on it...play with axles and brakes and motors and hunt down parts...and do things I might have an aptitude for...but it's all him now, until we get to some more assembly. He let me wet sand on it a bit over the weekend, enough to reinforce the fact that I don't care for paint. There's no joy to me...it's only anxiety...if you're not perfect, you're always judged by the 1% screw up...you can't take any pride in the other 26 outs you got...that last bunt single haunts you. Let me tell you, I'm super glad Eric is on the gun and not me....maybe I should say under the gun
Old 01-27-2015, 05:32 PM   #260
72K5CSTDarkOlive
hahaha.. I bet he is.. That's cool he let's you wrench at the shop. The guys at my body shop let me come in and sand blast and check on the progress. They should be done with media blasting this week and I'm picking up my frame from the powder coat shop this Friday.
And I know what you mean by that 1%.. That's whole reason I decided to strip the front axle back down again and have it powder coated like the rear axle and all the parts under the hood so it all matches.. I knew it would have bugged me so I made the decision to do it right. It was costly and time consuming experience but I did learn from it.
Old 01-28-2015, 08:22 PM   #261
IronCanine
I'm trying....
IronCanine's Avatar
A lot of effort going in to getting the window to top fitment fully sorted before the top comes back off. As you know the driver's side was beyond horrible. The track that holds the top to glass weatherstripping had to be moved and some of the top finish lines modified to accommodate that move. The top drip rail on this side was massaged as well to make it match up with the windshield drip better and mirror the passenger side. Glass to top fit is much better...seeing as you can no longer fit your to-go order through without having to roll the window down...but a little more refinement to go yet.
Old 01-29-2015, 02:50 AM   #262
Chulisohombre
Chulisohombre's Avatar
Mine was primer for years. Window gap looking good. Keep at it. The end is in sight. I wish I had the money to Hand mine off to a good body guy. Eventually I will get a professional paint job. But for now it's rattlecans just to keep it looking decent from a distance.
72 3/4 ton blazer. 5 inch lift on 35 inch tires. 355 corvette engine with crane roller rockers, rv cam, edelbrock carb and intake with one inch spacer. Thrush Headers with flowmaster 40 duels. 4speed sm465 manual. 4 wheel disk brakes with Inboarded rear shock prerunner style mounts and shocks.
Chulisohombre is offline   Reply With Quote
Old 01-29-2015, 10:51 PM   #263
IronCanine
I'm trying....
IronCanine's Avatar
Very happy moment when I got home and checked the front steps. Thanks a bunch Tim (TruckSeats). Side panels look outstanding. Looks like TruckWorld does a great job, but from my point of view, it seems like they might be difficult to deal with. Thanks Tim for making this happen. Hopefully the seat covers will be here soon too.
Old 01-30-2015, 03:53 PM   #264
IronCanine
I'm trying....
IronCanine's Avatar
JUST TO BE CLEAR...vendor TruckSeats (Tim) has been great. The manufacturer, TruckWorld, has been difficult. Their quality is great, but turn around and communication is not. It seems to me that Tim has a hard time going between impatient customers (me) and a difficult manufacturer (TruckWorld).
Old 02-04-2015, 09:44 PM   #265
IronCanine
I'm trying....
IronCanine's Avatar
After an extra couple of days fiddling with windows and weatherstripping...finally got to the point where the top could come back off and begin the process of preparing for some color. There is a strong possibility that once the top goes back on, it'll never come off again...(at least under my watch)..I know, heresy right?
Old 02-04-2015, 09:46 PM   #266
IronCanine
I'm trying....
IronCanine's Avatar
A neat little nugget inside the passenger's side hatch hinge.
Old 02-04-2015, 09:48 PM   #267
72K5CSTDarkOlive
does Truck World have a website? I'd be interested in seeing if they have rear side panels for our Blazers
Old 02-04-2015, 10:00 PM   #268
IronCanine
I'm trying....
IronCanine's Avatar
No website. You have to go through a vendor. I used TruckSeats (Tim) who is obviously on the board here. I ordered from Tim, he in turn ordered from them. They definitely do have side panels. That's who made mine...In fact, TruckWorld may be the only manufacturer of the side panels...I'm not sure they aren't the place Brothers' and others get theirs from...anyone who knows for sure please correct this.
TruckWorld does great work...but they are in no hurry. I tried to order my interior last summer because I knew they'd need a big lead time....but apparently the "scroll die" broke the week before I called...literally. Tim wouldn't even commit to take my order(read:my money) until late fall because he had no guarantees. Now it's February and I've got my side panels...but have no idea when to expect my seat covers...but as you can see by the preceding pics...I've got a little time yet.
Old 02-04-2015, 10:15 PM   #269
72K5CSTDarkOlive
I wonder where he gets them from. Fortunately, for me the only interior that needs replacing is my rear side panels and carpet. I assume these are made in the USA? (AKA China) lol kidding aside, If it takes that long then their quality must be good.
Old 02-04-2015, 11:01 PM   #270
IronCanine
I'm trying....
IronCanine's Avatar
TruckSeats gets them from TruckWorld...they are made in the USA. Quality is very good.
Old 02-04-2015, 11:07 PM   #271
DeadheadNM
Carpe manana
DeadheadNM's Avatar
x2 - quality is better IMO than OEM. Lots of real stitching involved and they use the correct walrus grain vinyl.
Old 02-04-2015, 11:40 PM   #272
72K5CSTDarkOlive
I should probably request my order now if it takes that long
Old 02-04-2015, 11:43 PM   #273
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Mine took six weeks...
Old 02-05-2015, 01:29 PM   #274
1956cameo
1956cameo's Avatar
You are doing a great job! This thing is going to be one heck of a nice rig when you get it done. Looking forward to seeing more.
I don't always drive trucks; but when I do I prefer Chevy's. Stay driving my friends.
'72 blazer 2wd build
67-72 Factory Big Block Registry
1956cameo is offline   Reply With Quote
Old 02-05-2015, 02:55 PM   #275
IronCanine
I'm trying....
IronCanine's Avatar
Thanks...I hope so...and don't worry you will.
1970, blazer, k5 blazer, restoration, silver
