10-01-2013, 05:11 PM | #76 |
Re: HOW TO: Crossmember sectioning ...
Chief, Thanks for the write up! Here is a nudge on finishing the steering!
10-01-2013, 06:16 PM | #77 |
Excellent write -up! Thanks for taking the time.
1963 Chevrolet Suburban |
10-02-2013, 07:08 AM | #78 | |
Hollister, CA.
Thanks for the much needed nudge .... Super busy at the shop, gotta make time !
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
10-02-2013, 11:55 PM | #79 |
life does "get in the way" of our projects, been working on mine since 98' and just now bout to finish my complete frameoff resto. man that frame work is Bad Ass.
10-03-2013, 01:17 AM | #80 | |
Fun Stuff
http://67-72chevytrucks.com/vboard/s...d.php?t=465423
Jay 68 C10(project) 88 Honda Accord(DD) 93 Chevy Astro EXT 2wd |
10-04-2013, 10:15 AM | #81 |
How are you going to brace the upper a-arm bracket? The holes are now above the frame.
10-04-2013, 10:27 AM | #82 | |
Hollister, CA.
Modifying the stock steering is my intention here.
10-04-2013, 10:30 AM | #83 | |
Hollister, CA.
Angle, tubing .... I was planning on molding the reinforcement into the frame.
10-04-2013, 06:06 PM | #84 |
thanks for all the great pics and write-up chief! ill be watching for sure!!
02-06-2014, 11:50 PM | #85 |
Awesome thread and great write up. Curious as to why you go to the newer style crossmember?
02-07-2014, 08:03 AM | #86 | |
Hollister, CA.
A '63 and UP crossmember does not need to be changed. I only changed it because I wanted to get rid of the Torsion Bars (60-62), and upgrade to a coil suspension.
02-07-2014, 10:10 AM | #87 |
Thanks makes sense now that I think about it. I have a 67 GMC that I will be doing the same thing to. So this was a great thread to run across.
06-01-2014, 12:44 AM | #88 |
But Found Her 25yrs Later!
I've been reading lots of threads on Sectioning, Z-Frame, and Notching the Crossmember.
It took me awhile to visualize what is happening with each option, and I really like the Sectioning method the best for one major reason. The Crossmember Notch, and Z'-Frame both raise the motor. Or I should say; lower the body and frame down without lowering the motor in relation to the drop. But with the Sectioning of the Crossmember, the motor drops along with the frame and body. For many of us 60-66 guys, this works out better. Because a lot of us running an HEI are already right up against the firewall with the cap. Lowering the body and frame without lowering the motor could cause us some issues with our distributor caps hitting the firewall.
06-04-2014, 09:57 PM | #89 | |
1965 C10 Project |
06-06-2014, 08:04 AM | #90 |
You are right sir. We all become GM engineers at some point in our builds. This site brings all of us together. Not sure I would tackle this. But I'm thinkin about it.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
06-25-2014, 12:16 AM | #91 |
thank you very much for the write up chief!
01-24-2015, 01:50 AM | #92 |
trying to give this thread some life!!! ..hey chief...did you ever finish the burban..
1966 C10 "Mary" 1972 C10 Cheyenne "Betty" https://67-72chevytrucks.com/vboard/...d.php?t=847364 1976 C35 Sierra Grande "Mr. Harvey" 1979 C10 Silverado "The BIG TEN" https://67-72chevytrucks.com/vboard/...d.php?t=841339 1982 C10 Silverado "Lucy" C10 Club Texas -HMIC |
01-24-2015, 03:31 AM | #93 |
Hollister, CA.
Thanks man ....
Not yet, but it's going pretty good.
01-24-2015, 07:55 AM | #94 |
Cool cant wait to see some pics...
Ok question...is putting a crossmember from a 71 a bolt in and then just transfer all the steering over (a-arms,draglink,pitman,idler arm) and what about the back..i have no experience with torsion bar set up.im buying a 60 panel and i want to drop it...
01-24-2015, 09:20 AM | #95 |
This thread helped me quite a bit
01-24-2015, 12:16 PM | #96 |
Need to take a cruize down to your neck of the woods with Luca some weekend.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
01-24-2015, 02:29 PM | #97 | ||
Hollister, CA.
More pics are in the actual build thread .... The crossmember will swap into a 62 and earlier chassis, but you need to redrill some holes. This is beneficial in centering the wheel in well in dropped applications ... Im glad !! Quote:
Anytime .... im headed to Turlock in a few
01-25-2015, 09:37 PM | #98 |
How does it help in centering the front wheels ?
01-25-2015, 10:42 PM | #99 |
Hollister, CA.
By relocating the crossmember about an 1" forward, it centers the wheels in the fender opening.
This would be in dropped, bagged situations
01-25-2015, 11:10 PM | #100 |
I thought about that, but what do you do about the taper of the frame ? My 64 begins to taper in just ahead of where the crossmember originally bolts in. Sorry to ask too many questions
