Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 01-24-2015, 07:49 PM   #5
nicks diner
nicks diner's Avatar
Re: Wheel hop issue
Originally Posted by Super73 View Post
You don't need to go coil over if you put a well thought out suspension together.
Trailing arm rear suspension?
Stock replacement lowering spring?
What shock is in it now?
Unlike the lowering spring used on the front (short and stiff) the rears I have used are actually pretty good, not overly stiff. A poor shock will not control a soft spring and the axle well want to bounce.
I would start with am adjustable shock. Look for a Rancho 9000 that will fit under your truck. Measure eye to eye of your current shock. Find one that puts your existing length in the middle of max extended and compressed length.
Yes trailing arm
ccp 5' springs
Bel Tech shocks
nicks diner is offline   Reply With Quote
