rotors
i have a 72 1/2 ton 5 lug.bolt patern is 5x5,what year rotor can i use that has 5x4.75 bolt pattern?
Re: rotors
Truck rotors or just Chevy rotors in general? Not sure they ever made truck rotors in 4.75 but general Chevy rotors in 4.75 would be Camaro, chevelle, impala up to mid 70s I think. S10s and blazers and novas and anything car pretty much.
Jack Personal Fleet: Family Fleet: 1955.5 Panel 1959 Apache 1968 ShortWide 1969 ShortStep |
Re: rotors
would you happen to know if the car rotors would fit on the truck spindle
Re: rotors
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
Re: rotors
thanks for the info
Re: rotors
I think you can put the Camaro rotors & 81 - 87 calipers on early spindles. The inner bearing is the issue , A13 bearing has the correct ID for the 71-80 hd rotor , but the correct OD for the Camaro rotor. I haven't tried it , just putting it out there fore someone else to! - Bob
