5.3 and flat top pistons
Ive got an Lm7 engine that needs new pistons, and I figured I'd just go with some flat tops. Now is there anything special I need to know before going about this? Are there any different dimensions between say the 4.8's which came with stock flat tops, and the 5.3's which are dished? I know this will through the compression up to 10.4:1 or around there and I"m good with that
Current project: 1972 Chevy c-10 350 (700r4 hopefully) - "Lola" 68 Oldsmobile Delta Custom 455 78 Z/28 Camaro - "Rocky" 89 Camaro RS 305 TBI DD - "Betsy" |
Re: 5.3 and flat top pistons
The dimensions are the same for Pistons, you can put a 5.3 crank in a 4.8 and you have a high compression 4.8
there's a youtube vid where buddy swapped the flat tops outta 4.8 into a 5.3...
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
After like 05, the 5.3s started coming with flat tops
