Anybody use these ??
Anybody use the brackets that bolt to your drum spindle to convert to disc brakes. They use 95 to 98 gm 2500 truck rotors and calipers, retaining your 6 lug bolt pattern.
Kirk Myers 68 chevy swb owned since 87, under the knife 71 skylark 9.20's @ 76mph 1/8 mile |
Never Ending Projects
Re: Anybody use these ??
What brackets? Never heard of this combo.
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
![]() Join Date: Mar 2011
Got any pics, and more info. News to me...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
scarebird.com
I looked into those before I bought drop spindles and cpp 6 lug rotors.
the only reason I can see to use those would be access to oem 6 lug rotors. cpp 6 lug rotors are less than a pair of light duty 3/4 ton rotors and unless you have a catastrophic failure cpp rotors can be at you door in under a week with free shipping from summit
1967 C10 lwb two tone, 305 & rat fink style floor shifted 700r4, 20" steelies 2004 2500HD utility bed aka Brutus |
Why not swap in 73-87 c20 spindles?
