Old 01-26-2015, 03:09 PM   #1
blosmde
blosmde's Avatar
6 lug torq thrust st or summit legend fitment
Hey guys I am very interested in the AR Torq-Thrust ST 6 lug / 6 spoke 20" or the Summit Legend 6 lug / 6 spoke 17" wheels and I was wondering if they fit and if some of you out there have them on can you post some pics? I am talking about these wheels http://www.summitracing.com/parts/ar...38nc/overview/ or http://www.summitracing.com/parts/sum-141-7883c0
blosmde is offline   Reply With Quote
Old 01-26-2015, 05:26 PM   #2
CST10
CST10's Avatar
Re: 6 lug torq thrust st or summit legend fitment
I like the torq thrust but 20" don't leave much rubber for cushioning the bumps.
MyToys:
Goldilocks the "Ol School Survivor" 1968 C10, SWB Stepside, 08/15 TOTM, 250 CI 6 cylinder, 3 on the tree, 3.73 rear, 3/5 static drop, 23,500 original miles.
Samson the 1970 CST10, LWB, 462Ci, Turbo 350 tranny, 3.08 rear gear, PB, PS, A/C, AM/FM, 2/4 Drop.
Brutus the 1998 Camaro Z28, 33,500 original miles, LS1, 519 RWHP/497 RWTQ.
Member of the Louisiana Classic Truck Club, LCTC
Member of the Louisiana C10 Club
Member of the Baton Rouge Drifters Car Club
CST10 is offline   Reply With Quote
Old 01-26-2015, 05:46 PM   #3
WarMonger
WarMonger's Avatar
I like the Summit 17" ones. I have a 70 C20, 6 lug
WarMonger is offline   Reply With Quote
Old 01-26-2015, 07:55 PM   #4
CST10
CST10's Avatar
I rather the 17" for sidewall cushioning.
MyToys:
Old 01-26-2015, 09:25 PM   #5
Mike C
Mike C's Avatar
I have the 5 lug version of the Summit wheels on my truck. I have 235 55 17 front tires and 275 55 17 rears. Front rims are 17 x 8 4.5" backspace and rears are 17 x9 5". I have the wider 5 lug 71-72 rear on my shortbed and that's about a big a tire as will fit without mods.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 01-27-2015, 12:59 AM   #6
Lattimer
Lattimer's Avatar
I like the graphite color Summit ones. Been thinking of getting a set for my truck so I can switch the look.
Shawn
1970 Chevy C-10 SWB, 350, TKO 600 5 speed
My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881
Lattimer is offline   Reply With Quote
Old 01-28-2015, 01:40 PM   #7
blosmde
blosmde's Avatar
Thanks for the responses...WarMonger and Mike C did you have to modify the rims at all? I have heard some need to have the lug holes drilled out a bit.
Old 01-28-2015, 01:42 PM   #8
WarMonger
WarMonger's Avatar
I did NOT have to mod the lug holes, but I did have to open up the center hole of the rim a little to mount flush to the drums. Does that make sense?
Old 01-28-2015, 01:50 PM   #9
blosmde
blosmde's Avatar
Thanks again WarMonger! Yes it does make sense! That is actually what I have heard before...Were you able to do it yourself or did you take them to a shop?
Old 01-28-2015, 02:58 PM   #10
WarMonger
WarMonger's Avatar
Harbor freight die grinder and some burr bits. I had a buddy kept shooting the bits with wd40 while I was grinding so they would not get clogged up with the aluminum. It took about 10 minutes per wheel. I would grind a little, test fit, grind a little test. Do that about 6 times.
Old 01-28-2015, 08:42 PM   #11
Mike C
Mike C's Avatar
6 lug in general is a pain to find wheels for. The aftermarket 6 lug wheels are designed for the late model 6 lug trucks and not the early large center.
Wheel selection is why I converted to 5 lug. And with the 5 lug wheels there is absolutely zero mods needed. With the 9" rim in the back I needed the extra width of the 71-72 5 lug axle in order for the wheel/tire combo to fit.
44 Willys MB
52 M38A1
64 Corvette Coupe
