Old 01-23-2015, 09:03 PM   #1
agnes the dog
agnes the dog's Avatar
Can't get rear leaf springs out
I'm trying to remove my rear leaf springs to do an axle flip. I can't get the rear shackles loose. I can get the nuts off without any problem, but the shacles won't budge. Anyone have any suggestions? Are they threaded? If so, how do you get them out? Thanks, jj
Just because you can, doesn't necessarily mean you should.
1959 3100 stepside 355 + T5
agnes the dog is offline   Reply With Quote
Old 01-23-2015, 09:23 PM   #2
franken
Re: Can't get rear leaf springs out
Truck is resisting being lowered?
I'd imagine the bolts are rusted to the bushing sleeves so you can't remove the bolts.
Got pics?
Old 01-23-2015, 10:14 PM   #3
Stepside Jim
Yes, there is a threaded situation going on. The pin is threaded into the leaf spring. Where you are having difficulty is getting the shackle free from the pin. In the picture below you will see between the threads of the nut you have removed and the large threads that go into the leaf spring is a tapered section, your shackle is wedged onto this taper.
Knock the shackle free from the taper and you're good to go.
My 57 Chevy truck build.http://67-72chevytrucks.com/vboard/s...d.php?t=541132
Stepside Jim is offline   Reply With Quote
Old 01-23-2015, 10:45 PM   #4
1958
Try putting some heat on it.
1958 is offline   Reply With Quote
Old 01-24-2015, 01:13 AM   #5
mr48chev
mr48chev's Avatar
You also need to support the spring so that you have the least amount of tension and or pressure on it. I've fought that one more than once with the weight of the rear axle hanging on the spring. Even just the weight of the spring adds extra friction to overcome.
Some rust penetrate like PB blaster or heat would help a lot in breaking the shackles loose from the bolts.
My ongoing truck projects:
Old 01-24-2015, 09:09 AM   #6
agnes the dog
Thanks!!! That's the info that I need! The pic really helped me see what I'm up against.
Old 01-25-2015, 02:26 AM   #7
1958Warrior
1958Warrior's Avatar
I had a hell of a time getting mine out due to them not being greased since it left the factory.
I found all the replacement parts bought separately was cheaper than getting new shackle kits:
just so you know autozone carries the pins cheap $6pr
http://www.autozone.com/parts/suspen...65_10195_1685/
and rare auto parts sells the threaded bushings $10 (if I remember right it was for a pair)
http://shop.rareparts.com/smtp/shopd...040|SUSPENSION, SPRINGS & COMPONENTS
and NAPA had the front bushings for the rear $10 think it was for the pair also
http://www.napaonline.com/Catalog/Ca...450_0131133059
1958Warrior is offline   Reply With Quote
Old 01-25-2015, 03:01 AM   #8
mr48chev
mr48chev's Avatar
If you need to change the bushings when you get it apart it would probably be simpler to take the springs to someone with a hydraulic press to do/have it done as they are a real pain to do on the work bench.
Old 01-25-2015, 03:23 AM   #9
1958Warrior
mr48chev as you say :
"While I'm at it I may as well----"
Old 01-25-2015, 01:09 PM   #10
_Ogre
_Ogre's Avatar
isn't there a tapered lock pin to remove on the front pin too?
your not going to reuse any of the shackle hardware, you can heat, cut or beat into submission the shackle
the replacements are cheesy, at least the ones i bought from brothers were
no nuts on the pins like stepside posted, just a 1/4'' bolt in between the plates
i see that rusing out in a few years and the shackle blowing apart
shop air compressor timer
Old 01-25-2015, 01:53 PM   #11
agnes the dog
Here's a pic of what I have. This is after I got the nuts off.
[IMG]
Old 01-25-2015, 02:17 PM   #12
1958Warrior
The pins/bolt has a taper to it where the shackle is , should be able to take a pry bar and pop it lose ,take a few good wacks at it as it was pressed on by the nuts.
Old 01-25-2015, 02:55 PM   #13
1958Warrior
And yes lock pins secure the front pin in the eye of the leaf spring mount,they're tapered also.
http://www.rockauto.com/catalog/x,ca...parttype,13713
When I did mine I had the bed off .
Old 01-25-2015, 03:50 PM   #14
_Ogre
_Ogre's Avatar
yup, they are just stuck on there now. smack the plate and see if it will pop off
non of that will be reused and unfortunately that end is often the easy end
the front pin ''slides'' out, first pull the tapered pin out that looks in the front pin
i made a slide hammer to screw in where the grease zerk was
try to center the spring on the pin as there is usually a wear spot that prevents the pin from extracting
Old 01-25-2015, 07:39 PM   #15
1958Warrior
All the pins and bushings are replaceable, I reused the shackles, much cheaper than new shackle kits, even was able to reuse the lock pins.
[IMG][/IMG]
I had to cut the pins and drive out the pins and bushings on the rear hangers, due to being seized. Hope you don't have to go that route.
Old 01-25-2015, 08:25 PM   #16
OrrieG
OrrieG's Avatar
Mine came out easy, the po had just repaired using undersize bolts and garden hose to take up the slack. I discovered it in 85 when I put the new axles on. Sure road and tracked a lot better afterwards.
Old 01-26-2015, 02:46 PM   #17
_Ogre
_Ogre's Avatar
Originally Posted by OrrieG View Post
garden hose
got to love that one orrieg
Old 01-28-2015, 06:18 PM   #18
bensimmons_05
bensimmons_05's Avatar
If you are replacing the spring bolts and bushings you can make use of a slide hammer. I had to also get the blind hole puller attachment with 1/2 -20 threads(same as spring bolt outer threads) and I welded two lug nuts together and hammered away. The bushings came out fairlly easy... and NOTHING came apart easy on the frame I had!
---Ben Jammin's 1955 Chevy/GMC Project ---
---The shop's live video feed--- <<< See what I'm up to!
bensimmons_05 is offline   Reply With Quote
Old 01-28-2015, 06:27 PM   #19
octanejunkie
octanejunkie's Avatar
The front eye of the rear spring is SO much easier to do with the bed off.
Déjà vu. It's that feeling you get when you hit your thumb with the hammer a second time
'59 Chevy 3100 Stepside
octanejunkie is offline   Reply With Quote
