Roadside Rebuilder
Shenanigans.
So here's one for you--
Driving my '74 LWB (2wd with a 250 L6) to work the other night (I'm a trucker, so I work weird hours), I started hearing what sounded like belt noise. I wound-down my window, pushed the clutch in and gave the truck a bit of fuel to see if the noise would go away, or change pitch. My efforts were greeted by the mother of all backfires--like a 1/4 stick of dynamite had gone off in my muffler!--and the truck promptly died. I coasted into a parking lot, and discovered coolant dripping from my cross-member. Fearing the worst, I gave the engine a visual once-over, and discovered a loose distributor-clamp and what I suspected was a bad water-pump. I tried a few eye-ball/hail-mary settings with the distributor, and she coughed to life, then died and that was all she wrote. Figuring I'd fouled the plugs trying to start it, I called AAA and towed her home. I did have coolant and a a 9/16 with me, and I couldn't believe that I couldn't get started, tighten down the distributor and limp it home... When I returned from work 24 hours later, I put the key in the ignition, and she fired right up. Sounded fine. I let her idle until warm, went in the house to grab my timing light, and when I came back outside... She died again. Being exhausted, I said screw it, and went inside to get some rest. Next day I put a new water-pump in, and static-timed her. Pulled the carb apart and gave it a once-over in case the back-fire had caused problems. Everything looked good--the backfire had been in the tail-pipe--so I reassembled and installed my carb, checked for fuel and spark, turned the key, and she coughed, tried to start, and then died. No amount of trying would get her to run. Being as the truck is my daily-driver and I had to go to work again, I hit up a mechanic-friend to take a look, and went on another 1000-mile trucking odessey. Went by his shop today, and all is well. It seems the spade-connector for my coil ('75 HEI with a separate coil) loosened up, and totally-unrelated but right around the same time, the water-pump started weeping, and the fan tossed the coolant onto the upper-hose, and it leaked down along an adjacent wiring loom, and into my distributor-clamp, which vibrated loose... Wild! Every time I reached in to turn the distribtor cap, I would brush against the wires leading to my coil, and the loose connector would alternately make or break contact. Madness! Talk about chasing a gremlin... Anyway, one new connector later, all is well. We warrantied the enitre coil assembly, just in case. Well, all is well except that monster-backfire found the weak-point in my 41-year old muffler... But that's a problem for another day. Soon... |
![]() Join Date: Jul 2014
Re: Shenanigans.
You are a better man than I! My take away is I need to get a AAA equivalent, or I will be in big doo doo someday. I had AAA, but years ago I bought into their "zero" interest credit card transfer offer, which they then sold to BofA... and most people know where that story goes. I called AAA and cancelled my long time membership and when asked why, I told them.
But, I digress. I know my Allstate agent can set me up with their version of AAA. Thanks for the timely reminder! I have been living on borrowed time too long!
--Project BABA YAGA!... http://67-72chevytrucks.com/vboard/s...d.php?t=655783 --Project BABA YAGA!... http://67-72chevytrucks.com/vboard/s...ghlight=Belair "Life is tough - wear a cup!" "Old Enough to Know Better - Too Young to Resist" "Junk is something you will need three weeks after you throw it away." |
Roadside Rebuilder
Re: Shenanigans.
Yep, four service calls (gas, jump-starts, lockout, or tows of up to 100 miles) per year, for $130--per cardholder. Subsequent calls are $50...
When one daily-drives an unrestored '74 GMC, it's the right move for sure. My truck only has 91K on it, but it is 41 years old... |
Re: Shenanigans.
I hear ya!
My 74 C20 has a tendency to lull me into a false sense of security... starts every time with a supple twist of the wrist, doors close nice, cab is dry, shifts solid, great mileage, everything works like it should... who needs no stinking roadside assistance!? Then it happens....
Re: Shenanigans.
This is exactly why I use a OEM connector for the coil power on my HEI distributor. The cap I have and the OEM connector allows for a locking mechanism that won't allow a normal spade to pull out or become damaged.
Your lucky it was a simple fix. |
Roadside Rebuilder
Re: Shenanigans.
| Bookmarks |
