01-27-2015, 11:03 PM | #1 |
bagging a 66' c10 ?s
Hello I'm new to this forum and just got a 1966 c10 . I want to bag it, just got a few questions and would like any suggestions. For the rear will I need to relocate my shocks? I'll be running 2600s with a small c notch. and for the front I'll be using the bag plates and possibly 2600s or 2500s.
01-27-2015, 11:14 PM | #2 |
Re: bagging a 66' c10 ?s
I got the same questions for my 61 apache 10. Addition to this thread can you guys post up pictures of c10s that are bagged with a c notch but not with an excessive frame work.
01-28-2015, 01:15 AM | #3 |
Jesse, Instead of relocating, I think you can just get shorter shocks if your going with a small C notch, You guys will both just want to remove the coil springs and place the bags there, You can use lowering blocks to fine tune your height after that.
Good luck and post pics. Have a good week
64 C10 Fleetside LB 4 Sp/292 Build http://67-72chevytrucks.com/vboard/s...d.php?t=602438 70 GMC 1500 Fleetside LB 3OT/350 Build http://67-72chevytrucks.com/vboard/s...83#post6767983 76 GMC CCLB Dually Build http://67-72chevytrucks.com/vboard/s...d.php?t=691612 79 GMC 3500 Fleetside LB 454/400 90 Suburban Silverado 4x4 350/700R4 97 1500 Cheyenne Short Fleet 350/5sp |
01-28-2015, 07:50 AM | #4 |
Spend some time in the suspension section. Lots of good threads on bagging these trucks. On the back relocating the shocks and going to s shorter shock is needed. What happens is the angle of the shock gets to steep and the shock looses a lot of its dampening ability. For what you want to do look into the porterbuilt stage 1 front and stage 2 rear setup. Very good setup and good vendors here to get you going.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
01-28-2015, 09:36 AM | #5 |
Sorry but it's not just replacing your springs with bags. You would need plates on cross member, fabbed cups to snug in the lower control arm, and shock relocators. Dropped spindles with discs for those extra inches.
The back would need shock relocation, C-notch, and an adjustable panhard bar is a must. I did mine with Porterbuilt Stage 1 and 2. These kits come with the proper bolt on needs and can't go wrong. AZProPerformance has all you need. Travis there is very helpful and guide you. I know sometimes prices may put a setback at times, but think about it, it's your suspension. You wanna spend 200 bucks, you get that $200 ride, $1000 equals $1000 ride. I wouldn't even think about piecing a kit together, you'll really spend some $. Good luck and feel free to PM me for any questions.
"El Jerry" '03 3500 Duramax dually '96 1500 ext. cab Chevy '66 swb C-10 '63 Panel '60 VW vert '56 VW vert |
01-28-2015, 11:33 AM | #6 |
Agreed. I found that running front shock relocators improved the ride 100% too. I would also recomend the 2600s for the front. Borris aka way2lo2 has a complete kit for your truck with manual valves,vauges,tank,comp and all the goodies for $1000. Grab some spindles, 2" blocks with ubolts and you will be good to go. Takes 2 days to install. He has an install thread that will help wrap your head around the process.
GOD BLESS AMERICA! |
01-28-2015, 02:09 PM | #7 | |
Have a good week
64 C10 Fleetside LB 4 Sp/292 Build http://67-72chevytrucks.com/vboard/s...d.php?t=602438 70 GMC 1500 Fleetside LB 3OT/350 Build http://67-72chevytrucks.com/vboard/s...83#post6767983 76 GMC CCLB Dually Build http://67-72chevytrucks.com/vboard/s...d.php?t=691612 79 GMC 3500 Fleetside LB 454/400 90 Suburban Silverado 4x4 350/700R4 97 1500 Cheyenne Short Fleet 350/5sp Last edited by 64chevtruck; 01-28-2015 at 02:18 PM. |
01-28-2015, 10:43 PM | #8 | |
01-28-2015, 11:31 PM | #9 |
No worries man! I like your rides. Keep on truckin.
have a good week
01-29-2015, 01:49 PM | #10 |
This thread is yet another example of why this site rocks. People leave their egos at the door an offer answers to peoples questions. We all started somewhere with our knowledge and abilities and its nice to see people helping other people along in their journey.
Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
