01-29-2015, 08:32 AM | #1 |
gas gauge sticking on Full
I just bought a 2002 Blazer Extreme.
When the key/ignition is turned on the gas gauge goes to Full and stays. I know the tank is nearly empty because I have driven close to 200 miles on the last tank fill. When the key/ignition is turned off the gas gauge goes back down to Empty. Any suggestions of what to look for? I know enough about electrical to make me dangerous.
Robert Member 1532 |
01-29-2015, 02:28 PM | #2 |
blood type; Retumbo
Re: gas gauge sticking on Full
I'll bet your check engine light is on also with I believe a code P0463
Fuel level sender is bad. The tiny little fingers that wipe across the resistor are broken. Dorman makes a sender but since it has metal and plastic I ouldnt trust it. Go AC Delco
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card |
01-29-2015, 03:13 PM | #3 | |
Don't have anything to check codes with.
