Old 01-29-2015, 03:12 PM   #1
boatpuller
boatpuller's Avatar
I heard a rumor
That a hydroboost truck uses a different brake pedal than a vacuum boost ? Experts ?
" Never look up a dead dogs butt."
boatpuller is offline   Reply With Quote
Old 01-29-2015, 03:15 PM   #2
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Re: I heard a rumor
I know the bracket that the pedal is hung from is different.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 01-29-2015, 03:34 PM   #3
Keith Seymore
Keith Seymore's Avatar
Re: I heard a rumor
Well - I have the brake system release charts starting in about 1969.
If we had a search feature...I would post them up.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 01-29-2015, 03:34 PM   #4
boatpuller
boatpuller's Avatar
Re: I heard a rumor
Thanks Jim..I had a guy tell me he thought pedal was different now he could have meant the whole assembly I guess.
Old 01-29-2015, 03:39 PM   #5
Keith Seymore
Re: I heard a rumor
You didn't say what year or series, but I checked 1987 R20 JB7 vs JD7:
Pedal ratio is different between the two so the pedal itself is different.
Vacuum = 4.51:1
Hydraboost = 5.60:1
K
1979-1986
1986 - 2019
Old 01-29-2015, 03:42 PM   #6
boatpuller
boatpuller's Avatar
Re: I heard a rumor
Thanks Keith. Its on my 79.sounds like I need the whole assembly.
Old 01-29-2015, 06:28 PM   #7
68Timber
I know the pieces fit
68Timber's Avatar
Re: I heard a rumor
I have a clutch pedal assembly for vacuum brakes but was told by a member here to change the brake rod mounting point to the upper spot for use with hydroboost. He sells a lot of pedal assemblies here so I took it he's seen enough of them to know.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 01-29-2015, 07:22 PM   #8
nonstop
Re: I heard a rumor
I just checked my truck - it feels like there is another hole to move the rod to higher on the pedal. I didn't look at it though. Might just be as simple as moving holes.
nonstop is offline   Reply With Quote
Old 01-29-2015, 10:38 PM   #9
boatpuller
boatpuller's Avatar
Re: I heard a rumor
Thanks Bruiser and nonstop.....Any info help's.
Old 01-29-2015, 10:52 PM   #10
UKNOWME
UKNOWME's Avatar
Re: I heard a rumor
K
Yeah what's up with that?
2018 Audi S5- wife's ride
1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511
1981 Chevy Silverado- in pieces
1964 Chevy c10
2017 Jeep Wrangler JKU
UKNOWME is offline   Reply With Quote
Old 01-29-2015, 11:05 PM   #11
1774btcrew
1774btcrew's Avatar
Re: I heard a rumor
The brake pedal is essentially the same from hydroboost to vacuum. There is an additional hole in the pedal. What this means is if you wanted to go from one to another you would have to weld the bracket that attaches to the pedal in the corresponding hole for the brake system you are using. If you can't weld or don't want to mess with it, you can unbolt just the brake pedal and switch it out. Hydroboost also has a teardrop shaped plate that a spring attaches to for the pedal return. Please let me know if you have any other questions. I sell a lot of these pedal assemblies.
AZPartsLocators on Instagram
1972 Cheyenne Super Short Bed big block "Blackie"
1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog"
1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck.
1774btcrew is offline   Reply With Quote
Old 01-30-2015, 12:54 AM   #12
nonstop
Re: I heard a rumor
I guess this leads me to more questions than less:
First, would it be possible to run a grade 8 bolt through the top hole and use that as the pivot if you tack welded the head to the pedal and used a lock nut on the other side (I still don't trust my welding to something as crucial as the single pin charged with stopping the vehicle)?
Second, I love my hydroboost and it was night and day when I did the conversion, but why does hydroboost have a higher ratio than the vacuum booster when hydroboost puts out a lot more pressure to begin with?
Thanks!
Old 01-30-2015, 08:03 AM   #13
68Timber
68Timber's Avatar
Re: I heard a rumor
Thanks!
Wouldn't it be less ratio? The closer to the pivot point, the shorter the stroke?
John
74 Honda Z50 build
Old 01-30-2015, 09:33 AM   #14
Keith Seymore
Re: I heard a rumor
Correct - shorter stroke, but stroke is not the same as ratio.
Moving the rod to the same place you put your foot would be a 1:1 ratio. Moving the rod up any amount from there would be an increase in ratio.
1979-1986
1986 - 2019
Old 01-30-2015, 09:36 AM   #15
Keith Seymore
Re: I heard a rumor
Thanks!
Because it's a system. All of the variables in the booster, master cylinder and pedal are tuned together to get the correct feel, travel and response. You can't look at just one component out of context.
1979-1986
1986 - 2019
Old 01-30-2015, 10:51 AM   #16
1774btcrew
1774btcrew's Avatar
Re: I heard a rumor
Thanks!
The hole isn't the pivot point for the rod. It is the locating hole for the bracket! You need to move the bracket to have the correct stroke of the pedal. Just move the bracket and weld it on. I will try and post some pictures of a hydroboost pedal
Old 01-30-2015, 12:09 PM   #17
SCOTI
SCOTI's Avatar
Re: I heard a rumor
So.....
If a guy was going the opposite direction (Hydraboost system w/corresponding pedal & converting to a vacuum set-up), what would need to be changed as far as the pedal?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-30-2015, 12:16 PM   #18
1774btcrew
1774btcrew's Avatar
Re: I heard a rumor
As far as the pedal assembly goes, you would just need the vacuum brake pedal. Then remove the hydroboost pedal, spring, and the plate that attaches to the spring
Old 01-30-2015, 01:11 PM   #19
SCOTI
SCOTI's Avatar
Re: I heard a rumor
Weird.... I pulled the vac brake pedal. It appeared to match the HB one (length, arch, hole positions) so I left it in place.
Ok, next question is based on this info:
Vacuum = 4.51:1
Hydraboost = 5.60:1
It appears the HB has a higher ratio. Wouldn't that mean the HB pedal in a Vac app would yield more pedal effort all else being the same?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-30-2015, 01:31 PM   #20
nonstop
Re: I heard a rumor
Now I am even more confused! I have a stud where it is currently mounted and a hole about an inch higher. My rod sits at an angle now and would line up with the upper hole.
A picture would be great and much appreciated if possible!
Thanks.
Old 01-30-2015, 01:36 PM   #21
1774btcrew
1774btcrew's Avatar
Re: I heard a rumor
Something else to mention is if you want to correctly convert a vacuum pedal assembly to hydroboost, you will need to remove 2 studs from the actual pedal assembly where it goes through the firewall. The hydroboost uses a bracket that has 2 studs that go through from the engine side. Vacuum brakes have all of the studs go through from the interior side.
Old 01-30-2015, 01:51 PM   #22
boatpuller
boatpuller's Avatar
Re: I heard a rumor
Some good info......I'm doing exactly what Scoti said going from hydro to vacuum. I have a leaking hydro unit getting my engine bay oily. My truck is pretty much for show so any chance i get to replace something with chrome or billet I'm doing it.
The chrome hydro replacement is big $$$.. I can get a chrome booster and m/c for reasonable and it will bling it up a little.
So. I think I'm back to my original thought of pedal only to do the swap?
Old 01-30-2015, 02:08 PM   #23
1774btcrew
1774btcrew's Avatar
Re: I heard a rumor
Thanks.
I should have said it was a pin. What has to do with the throw is the angle the pin is at on the pedal. Pictures soon as it quits raining and I can go out and get the stuff.
Old 01-30-2015, 03:20 PM   #24
SCOTI
SCOTI's Avatar
Re: I heard a rumor
Exactly. My HB was definitely not functioning correctly & leaking everywhere. I opted to swap to a Vac set-up to help eliminate clutter under the hood when I started cleaning things up during the motor swap. I grabbed all the parts for a vac brake truck to allow comparisons & the ability to swap if necessary. I compared the pedals & sure didn't notice a difference.
Thus far it's worked but I've been bothered by a repeat leak @ the master cylinder that I hope has now been diagnosed as too long of an actuator pin between the vac canister & master cyl. I do feel the pedal ratio is off personally....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-30-2015, 05:26 PM   #25
boatpuller
boatpuller's Avatar
Re: I heard a rumor
You used the hydro pedal and it worked o.k Scoti ?
