width of rear tires
Hello to everyone, this is for my 72 Chevy C10 Fleetside. Will a set of 275/60/15 fit under my bed w/ the stock rear end and without widening the wheel housings? I'd like to install them on 15x8 rims as long as they don't stick out of the wheel wells. Thanks to all.
![]() Join Date: Dec 2012
Re: width of rear tires
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
OregonNed, thank you so much for the reply and the picture. The tires and the truck looks great. Thanks again, I appreciate it.
Im running the same thing on mine, no problem. I'm gonna keep the same size tire and put a 15x10 wheel on it. I still will have the clearance for it.
Really? I was thinking of of running 15x10 rims on the back but I thought it would be to much and have to widen the rear wheel housings. I'm wondering if they would stick out from the wheel wells?
laying low
![]() Join Date: Mar 2001
A tape measure is your friend.
![]() Join Date: May 2014
![]() Join Date: Feb 2012
Not a great pic but here is 15x10 with 295/50/15 on them
![]() Join Date: Jan 2012
what backspacing are the 15x10's. I'm going that route. Mine are 4" backspace. I still have to do the math.I was going to go 33x12.5x15. The wheel wells will take the size if the rim is spaced correctly.
It builds on my intelligence when I make a mistake, Boy am I building on it! '67 C-10,'70 Nova SS ![]() |
4.5 on the back spacing.
I was told the 10" should work fine on my truck... I like the 8" and the side walls aren't too bulbous....
Not a problem, Geos 72 and thanks Earnhardt!
Im running a 5" back space so they are tucked under the bed..
Ive got the 10 inch wide L50-15 on 10" slotted mags on mine with plenty of room
#15 |
I have 15x10s with 31x10.50x15 on the back of my 69 short bed fleet side with no problem.
