Old 01-25-2015, 06:47 PM   #1
forestb
forestb's Avatar
using a vacume pump as an airbag compressor
I have a SSBC electric vacum pump and was wondering if there were anyway to some how use it as an air compressor for air bags?
forestb is offline   Reply With Quote
Old 01-26-2015, 02:57 AM   #2
andrewmp6
Re: using a vacume pump as an airbag compressor
A vacuum sucks a compressor blows,I doubt you could change it over to work.I would sell it and use the money to buy a compressor,Some of our vendors on here have good deals.
Old 01-26-2015, 07:52 AM   #3
PGSigns
PGSigns's Avatar
The pump you have is a diaphragm type pump and they do a good job at making vacuum but not pressure. You will need to get a pump designed for making pressure.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 01-26-2015, 12:37 PM   #4
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Simple answer is no. One sucks, the other blows...
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 01-26-2015, 01:05 PM   #5
forestb
forestb's Avatar
Thanks for all the answers. Please don't get mad at me for asking another one. I was just wondering because the pump has both a intake tube and an exit tube. Is there any way to test and see if it produces enough pump pressure?
Old 01-26-2015, 01:28 PM   #6
PGSigns
PGSigns's Avatar
Not any way it will make much pressure. The one we have at work will make 12 or thirteen at the most and then don't have the power to push the diaphragm up. Found that out when I hooked one up backwards. No where close to the 150 needed for an air ride system.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 01-26-2015, 02:05 PM   #7
forestb
forestb's Avatar
thanks
Old 01-26-2015, 10:28 PM   #8
clemsonteg
I have a pump at work capable of doing 26 in. Hg of vacuum and. 100 psi of pressure depending on how I plumb it. It was also $600, so I think I would rather have my $150 444c
clemsonteg is offline   Reply With Quote
Old 01-27-2015, 07:48 AM   #9
PGSigns
PGSigns's Avatar
Is that a DC pump? or is she plugged into the wall?
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 01-27-2015, 07:53 AM   #10
clemsonteg
Jimmy
AC pump. Just one more reason to buy the appropriate compressor for the application.
Old 01-27-2015, 01:25 PM   #11
PGSigns
PGSigns's Avatar
Figured it had to be. The DC stuff we have for vacuum does not have near the power to do that. Ac is another story.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 01-29-2015, 07:42 PM   #12
502ms
502ms's Avatar
you want to have something that can fill your tank between 150-200 psi. And not take 20 minutes to do it
Best Regards,
Leon M.
502ms is offline   Reply With Quote
