01-29-2015, 01:59 PM | #1 |
1970 power booster install
Hey guys, so Im converting my truck over to disc brakes, and i just finished mocking up the power booster, my question is, do i hook up the pushrod from the booster back in the same location where the old one was on the pedal?, or do i have to make another hole for it?... Thanks.... Im running cpp disc brake conversion lines, and ebay power booster.
01-29-2015, 02:41 PM | #2 |
Re: 1970 power booster install
Mine is in the same spot. Brakes felt a little touchy until I got used to it, but after a few hundred miles I like it.
Shawn 1970 Chevy C-10 SWB, 350, TKO 600 5 speed My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881 |
01-29-2015, 08:06 PM | #3 |
01-29-2015, 11:57 PM | #4 |
I have the stock booster mount from a donor, and the stock power brake rod. I lenthened the rod as far as it would go to get as much pedal height as I could, but thats all. Pedal is closer to the floor than with the manual brakes, but still plenty of travel.
