Old 01-29-2015, 09:57 PM   #1
aod92
aod92's Avatar
Need help....Motor mounts not lining up???
Here's a couple of pics of what I'm dealing with. I'm trying to mock up my motor but the holes aren't lining up. Ece ls swap mounts going into a 67 that originally had an I6 motor. With these mounts I'm supposed to drill one hole in the cross member. When I line up the one bottom hole the mount sits too high from the top of the frame. I'm completely lost here. Your help is appreciated!
aod92 is offline   Reply With Quote
Old 01-30-2015, 12:42 AM   #2
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
Re: Need help....Motor mounts not lining up???
Think I would email some these pics and verify all the info with ECE to make sure those are in fact the correct mounts. I would also try fitting them to the motor then lower them with the motor/tranny/drive line (if you have it) to see where your at...Might get lucky and have to drill three holes instead of one...?
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 01-30-2015, 12:53 AM   #3
LockDoc
The Older Generation
LockDoc's Avatar
Those are '73 & up mounts. They are not a direct bolt in.
LockDoc
Leon
Old 01-30-2015, 12:57 AM   #4
aod92
aod92's Avatar
LockDoc
I bought them off of a guy who had them on his 68. He said they bolted right up. Would I be fine notching the frame to get the top bolts to line up?
Old 01-30-2015, 01:03 AM   #5
LockDoc
LockDoc's Avatar
Here is a couple of threads on the subject....
http://67-72chevytrucks.com/vboard/s...d.php?t=128765
http://67-72chevytrucks.com/vboard/s...d.php?t=366800
LockDoc
Leon
Old 01-30-2015, 01:12 AM   #6
aod92
aod92's Avatar
Thank you for the links, but I'm still a bit confused. The brackets I have seem to tall and those links don't address that problem.
Old 01-30-2015, 01:19 AM   #7
LockDoc
LockDoc's Avatar
I have never used them. The only truck I have seen with them in cut a notch out of the frame so the top holes would line up and re-drilled the bottom holes in the cross member to match the mounts. I think he only used one bolt in the bottom.
LockDoc
Leon
Old 01-30-2015, 01:21 AM   #8
aod92
aod92's Avatar
LockDoc
Ok, that's what I was thinking I would have to do. Thanks for your help.
Old 01-30-2015, 01:24 AM   #9
LockDoc
LockDoc's Avatar
No problem.
LockDoc
Leon
