Old 01-29-2004, 09:01 PM   #1
allthrtl
Available for Adoption
allthrtl's Avatar
Clearence problems....
Ok, got the -2.5" spindles and the -2" srpings on the front, as well as a flip kit in the rear. I was running 255/60/15's on the front and 275/60/15's on the rear all on 8" wheels with about 3.5-4" back space......Problem is the lip on the front fender contacts the tire when going over a decent size bump. Since the tires are only about a month old, I went back to the tire store hoping to make some sort of trade for narrow front tire, happily they were more than happy to take those back and try a different size...Well, we ended up with 235/70/15's on the front after also trying 255/70/15's. I haven't hit any bumps yet, but I can tell that they will still contact, although I do have a little more room than before....... Has anyone ever tried cutting the fender lip back about .5" or bending it upward to increase clearence? I realize the fender relies on the lip for stability, but if someone else has done it successfully, I don't mind giving it a try...........
Any advice??
1983 C10 SWB 2001 Silverado SWB 1995 Corvette
allthrtl is offline   Reply With Quote
Old 01-29-2004, 09:13 PM   #2
dacanuck
I haven't tried it, but I'm sure it wouldn't hurt to bend it, and cutting probably would be fine too. The fender IS held on at the bottom corners by a few bolts, not to mention the inner fender with it's ump-teen bolts to the fender. Or you could always cut off the lip and weld a thin plate of sheetmetal to the back of the fender if you're worried about strength. I read in Hot Rod years ago you can place a baseball bat against the tire while someone drives the car, and the bat will push your fender out to clear your tire!!!
86 GMC C15 swb. 350/TH350, fully loaded, but wish I had overdrive!
dacanuck is offline   Reply With Quote
Old 01-29-2004, 10:02 PM   #3
1FaastC10
1FaastC10's Avatar
if im not mistaken, its a pretty common practice to roll the fender lips.
1FaastC10 is offline   Reply With Quote
Old 01-30-2004, 12:15 AM   #4
allthrtl
allthrtl's Avatar
Cool, I knew I could (edit: couldn't)be the first person with this problem.... I'll get some before and after pics on here soon....Truck is starting to look alot better.....if ya squint you don't notice the faded blue paintjob.......
Old 01-30-2004, 01:45 AM   #5
brad2
I have had the same problem before and bought new tires just as you have. Have also rolled a fender lip with out any problems. Just go slow and work your way back and forth till you get it where you want it.
74 swb
71 2wd Jimmy
82 2wd Blazer
brad2 is offline   Reply With Quote
Old 01-30-2004, 01:54 AM   #6
ocbaud
Garage Queen Material
i run 275/60/15's all around.
i have 2.5" spindles and 1.5" coils.
the first few weeks after the drop, the tires would rub like that. i have little chunks that where tore off of the tire, from hitting the fender. what i did was roll the fender lip in so that it doesnt hit it
ocbaud is offline   Reply With Quote
