#501 |
![]() Join Date: Jun 2010
Re: 1958 Apache 38 Dually Dump Project
AD, haven't got into the lights too far yet but here's a little better pic of the parts and pieces of the HID kit...offered by a company called Kensun. They're going for about $100/kit...I think.
1958 Chevy 1 ton dually 4X4 dump/flat bed My build thread 1966 "Not-So-Original" Chevy Custom Trim Suburban My Time-Killing Project Truck 1966 GMC Extended cab 1 1/4 ton 4X4 My Son's build thread |
#502 |
![]() Join Date: Jul 2012
Thanks Rocktonka! Gotta check them out for my build. The old sealed beams leave a lot to be desired in comparison to what I've gotten used to with the newer wheels....and we have a lot of deer running around here. Better chance to see them with better lights.
Thanks again. |
#503 |
Changing things up a bit. We've been thinking that we needed to replace the retreads up front with new tires, and did that a couple weeks ago. As we were thinking of spare tire options and what would make sense, it somehow snowballed into new tires all the way around with new wheels.
![]() We've just got the front done so far (need to sell the old wheels/tires for the rest), but we're really liking the new set-up. ![]()
#504 |
Junk Yartist
Other than the caps over the lockouts that is just sick and will look awesome with the 58 body!
-Jeremy YOU ONLY FAIL IF YOU STOP TRYING 70 Crew Cab Build Link 70 GMC Suburban 4X4 build thread 95 Yukon Daily Driver Rebuilding an NP205 |
#505 |
![]() ![]() But, I kinda like the closed look ![]()
#506 |
Those are sweet.
Kim |
#507 |
Nice rims!
Success is not final, failure is not fatal: it is the courage to continue that counts. Winston Churchill DD 2000 Chevy Suburban 4x4/5.3 Vortec/4L60E/4:10s, 18" Escalade rims, Electric fans Project Dooley One-Ton 4x4 on 38.5s Corn-binder build |
#508 |
Thanks! We're pleased with them.
Got the open center caps in, and like them the least out of the three options of open, closed, or no cap. ![]() The open caps are deeper than the closed...looks kinda funny and makes for a hell of a crap trap ![]() The no cap look is fine, and would be the most practical, but I like the closed cap look best...it's only 2 phillips screws holding it on and would be easy to pop off when 4WD is needed.
#509 |
Nice wheels! I agree the closed cap looks better.
#510 |
I'd go with the closed cap also. Your truck should be able to carry a extra screwdriver in the tool box without it bogging down. You have a great build going on there. I like those big boy wheels and tires.
You have to have patiences or you'll be one. |
#511 |
I like the closed caps also.
Kim |
#512 |
A320 Pilot/USAF Retired
Closed caps!!
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
#513 |
Well, the board has spoken...closed caps it will be!!
#514 |
We got the rears done today...
#515 |
6>8 Plugless........
![]() Join Date: Sep 2007
I really like those wheels a lot! I almost put them on one of my projects before I sold it.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#516 |
Those wheels are sweet!
#517 |
Very nice.
Kim |
#518 |
Junk Yartist
Exceptional my friend. I don't think you posted about the bedsides yet, have you?
#519 | ||
![]() ![]() ![]() Thanks Kim! Quote:
#520 | |
Well, since you brought it up, we decided to jump back into the bedsides a bit. My son is sanding the old, weathered, finish off the bedsides before fogging them with a bit of black paint, partially sanding that down, staining them, and then we'll coat them with a few coats of urethane. Pics don't show the urethane yet..
#521 |
While he was working on those, I cut off the old bed rack gussets and welded in some new ones...
#522 |
Looks really nice.
Kim |
#523 |
Nice work! Are your dimple die tools showing any wear yet?
#524 |
I was thinking the same thing, that's one tool he's getting his money out of. Looks good and just think how many options you will have on where to place your tie downs.
Rob
My '47 C.O.E build |
#525 |
The rack gussets look good. Rocktonka you have me thinking about where I can incorporate dimples into my build. Really liking them....and those welds!
