Old 01-26-2015, 02:43 PM   #1
68_Step
Question 78 K30 Carburetor Issue
I have a 1978 K30 with a 454 that has never run like it should, so I decided it is tune-up time. Need to make it a more reliable ride. I knew the carb was a 600 double pumper, but have never paid that much attention to it. It is a model #4776, mechanical secondaries. I went to Holley's website to look up adjustment info and a found this as a description for my current carb.
"Intended for lightweight vehicles w/ manual trans or automatics with high stall & low gearing".
That is the exact opposite from what it is setting on: A 1 ton, 4 wheel drive, that gets used for hauling feed and hay and getting me to work when the snow is real bad...
Is a mechanical secondaries carb what I need for what I use it for?
What do type carb do I need to be looking for? CFM rating? Thanks for the help!
68_Step is offline   Reply With Quote
Old 01-26-2015, 06:52 PM   #2
mrolds88
Re: 78 K30 Carburetor Issue
That application is exactly what Holleys are good for. WOT. Get yourself a good early Qjet. Go through it and put i ton. Use either a Chevy or Cadillac unit. Make sure the number starts with a 70. The early units are tunable. Get a book if needed. They work well, very well. The 2 main parts to tune are the idle screws on the bottom in the front and the secondary air valve. A little tuning on one goes a long way.
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
Old 01-26-2015, 07:54 PM   #3
68post
A Qjet would be best , and get better mileage too.
The dbl pumper in question is so small for your 454 - the normal characteristics
don't quite apply. I'm sure it drives fine and has excellent throttle response , but if it were an 850 on a stock 454 - it would be a mismatch.
Do you have an aftermarket manifold, or is there an adapter under the carb ?
68post is offline   Reply With Quote
Old 01-26-2015, 10:49 PM   #4
68_Step
It has an Edelbrock Performer 2.0 manifold and headers, not sure if there is an adapter
under the carb or not but reading the description on Edelbrock's site it looks like the manifold is spreadbore - isn't the 4776 a squarebore?
Old 01-26-2015, 11:18 PM   #5
enaberif
1708 series Qjets are good too. I have a 800cfm version on my truck right and they are just as tunable as the 70 series. The 1708s also generally have a better provision for electric choke compared to the earlier years which are more hot air choke setups.
enaberif is offline   Reply With Quote
Old 01-27-2015, 01:15 AM   #6
68post
The 4776 is a sguarebore holley , and your intake can use it or a spreadbore carb. You may have a thin steel adapter plate under your carb, some manifolds require them so the squarebore carb will seal.
Old 01-27-2015, 10:10 AM   #7
68_Step
I wish that was true, it is running very rough and bogs down when you hit the gas hard. I am thinking I need to do compression checks and rebuild the distributor and carb - then decide if the carb is the problem. Over the past few years it has not seen much driving at all which may explain it's rough running.
Old 01-27-2015, 10:10 AM   #8
68_Step
Whew, thought I had written the wrong numbers down!
Old 01-30-2015, 12:56 PM   #9
68_Step
You were right. I pulled the carb last night, will be rebuilding it this weekend. It had a thin metal plate (in the square bore shape) between the manifold (really is spread bore) and the Holley 4776. The PO had 3 gaskets on it. Two between the metal plate and the manifold and one between the plate and the carb.
Do I really need 3 gaskets, or just 2 - one on each side of the plate? Do I use any sealer when putting is back together?
Old 01-30-2015, 05:41 PM   #10
Bears63
...just another truck junkie..
Bears63's Avatar
You should only need 2 gaskets, one on each side of the plate and don't use any sealer.
Mike "Bear" Shea
Bears63 is offline   Reply With Quote
Old 01-31-2015, 01:50 AM   #11
68post
Hope you find the issue. That 600 should perform like an economy carb on your 454. ( dbl pumper = bad for mileage/ 600 = small for even a 350 )
I used a 500 AFB on a warmed-up 350 many years ago - for the main objective of fuel economy , then - torque up to 4,000 max, hp be daymd !
Tim K.
84 K30 srw Silverado 454 auto
85 C20 350 C6P auto flatbed
94 K1500 lifted shortbed 350 4 bbl NV4500
Old 01-31-2015, 10:57 AM   #12
68_Step
The carb rebuild this weekend is a temp measure to get it runing decently again. I have been checking out the Holley 4160 #3310S, 750 with vacuum secondary. Took the carb apart last night and it is soaking in parts washer fluid. Will finish clean up this morning and put it back together. Also picked up plugs, cap...
Old 01-31-2015, 03:51 PM   #13
nonstop
What are you using the truck for? A Holley is great if you want to keep tuning it. A Quadrajet is a great carb for economy, but will definitely give you power. I have a 750 vacuum secondary Holley sitting in my garage, but I can not bring myself to throw it on. The Quadrajet just seems to run great on it.
nonstop is offline   Reply With Quote
Old 01-31-2015, 08:45 PM   #14
68_Step
Well the day did not end well. When cleaning I found a crack on the front right corner. Of course as I was fiddling with it the corner snapped off. Pretty sure JB Weld won't fix that! Since it looks like I am in the market for a carb, what do you guys suggest? This is basically a work truck so gas mileage is not a huge concern. I use it to pull a cattle trailer, haul post and wire, 1000lbs of feed at a time - you get the idea
Old 01-31-2015, 08:50 PM   #15
enaberif
Looks like someone tightened down the carb too much at some point.
Old 01-31-2015, 09:15 PM   #16
Fixwhataintbroke
Enthusiast
Fixwhataintbroke's Avatar
Honestly for as overwhelmingly simple as they are, i'd go with an edelbrock 1411. 750 CFM, vacuum secondaries (if i recall), and an electric choke. I use one on my warmed up 454 and it's about a perfect match.
- Cole
1979 Chevy C30 w/ carb 454.
1992 Chevy K1500 w/ tbi 350. *Sold*
1997 Dodge Ram 1500 w/ Magnum 360 *Sold*
"Good judgment comes from experience. Experience comes from poor judgment." - George Washington
Fixwhataintbroke is offline   Reply With Quote
Old 01-31-2015, 10:08 PM   #17
tucsonjwt
I just put a US Carburetor Qjet rebuild in my 83 454 and it seems to work OK. Of course, I knew that the "automatic" choke would not work properly because they never work for me, so I used my existing manual choke and that works fine. I got this carb because it was the cheapest, but I will have my original Qjet rebuilt by a good shop, probably Sean Murphy, and keep it in reserve. The US Carb is far from being a show piece - components look generic and lack the factory dichromate, teflon, and other coatings of OEM parts.
I have had many carbs for my squares over the years, and have never had good luck with the Edelbrock, and former Carter, carbs. The quality of the components was not as good as OEM and did not hold up very well over time. Plus, I don't think they make a Qjet spread bore direct fit, so you have to deal with adapters for their square bore base plate and jigger the linkage and air cleaner connections. So far, a high quality OEM Qjet rebuild seems to be the best option.
With all of the carbs, I highly recommend a manual choke. The factory chokes of any type (hot air, divorced, or electric) can never be adjusted to work properly in both cold and hot engine conditions. If you adjust them to close when cold, they don't open fully when warm. Or if you adjust them to open when warm, they won't fully close when cold. I have tried different types of coils in the choke housing with no success. I am sure many posters here will say they never have any trouble with their choke, but I have not been so lucky. For a $12 investment I know for sure when the choke is fully opened or closed, or I can keep it partially open if conditions warrant that.
tucsonjwt is offline   Reply With Quote
Old 02-01-2015, 09:45 AM   #18
68_Step
I agree 100℅, whichever carb I get it will be a manual choke. One less thing to worry about.
I think I have my choices narrowed down to either the Holley 3310s or the Edelbrock 1407. Both are 750s with vacuum secondaries.
Old 02-02-2015, 05:25 AM   #19
Your41Plague12
Your41Plague12's Avatar
Out of those two, go with the Edelbrock. I ran the 1411 (same thing, but an electric choke) and it was a great carb. Ran right out of the box, barely needed tuned.
Steve
Member of the Foot Pedal Club
'83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL,
Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws,
350 HP 350 crate engine from Jegs, Turbo 400
Your41Plague12 is offline   Reply With Quote
