Old 01-31-2015, 11:42 PM   #4
bcontractor
bcontractor's Avatar
Thumbs up Re: My power steering box install on a 61
Originally Posted by buds56 View Post
I cut the top rear bolt down and welded it to create a stud.
Drilled the two holes out on the steering box for the studs to fit through.
Box fit right on.
At the top on the back I welded the back of the stud and the plate to the frame, probably a little over kill, but thought there may be potential flex.
Right on brother !! I have REZ plates I bought long time ago [ a wife ago] ...check your clearance with the body of the box..it hits on mine.... I need to do a little grinding on the body [1/8] is necessary on mine to clearance it so it dont hit.....
I will be replacing mine with 1/2" steel plate and 16 gauge backup sandwich washer that I will be cutting on my Torchmate !!
bcontractor is offline   Reply With Quote
