Crossmember question/shocks
Why does everyone just run the flat plate for the upper bracket up front? Why doesn't anyone make a step style one that would allow the bag to go up inside the crossmember for a few extra inches? Would it weaken the structure if you had to widen it a little bit? I don't care about losing the lift if that's why it's not done?
To the guys running the 1950s mercury shocks, what mercury model/year or part number? Are you using these INSTEAD OF or WITH a relocation kit? Bags and tank will be here next week, already have valves and most of the electronics, just need a few elevel harnesses and i'm set! Getting excited. |
#2 | |
Re: Crossmember question/shocks
Excellent, then that's what I plan on doing; widening it enough to drop it an extra 2-3" from fitting inside the upper spring mount hole.
![]() Join Date: Jan 2011
With the flat plate and cupped lowers my cross member sits on the ground. The bags have plenty of room to completely reach there deflated height. No need to tuck them in the upper.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
#5 | |
I was going to ask what people are using for steering stops when they box/cup? |
#6 | |
Where I see the benefit of changing the upper or lower mounting position (pocket heights) is that it could help put the bag @ its ideal pressure range @ ride height if the traditional plate method doesn't allow it.
My static dropped truck ride height and the bagged truck are about the same. Low enough to look good tall enough to get in and out of parking lots. They are both riding on stock front crossmembers. Any lower for a ride height and the control arms become an issue with hitting the ground. Last thing I want to do is tear a control arm off the truck with the roads we have around here. Also to go much lower with the stock subframe would start to get the tie rod angles higher than I would like and induce more bump steer. If I wanted to go lower then I would need to go to a sectioned front cross member or a setup like a drop member. This will get the suspension raised up in the truck to get good geometry and ground clearance.
Jimmy
