mini truck racer
Re: New project
Quick update : I got the fuel system lined out . It is now set up for pretty much anything . It is -10 from the tank to the filter . Filter is on the pump inlet . Pump is Aeromotive SS which is good for 1000HP . -8 from pump to regulator which is a Aeromotive return style . -8 return to the tank and 2 -6 lines to the carb . Fuel pressure is rock solid . Started the truck up on pump gas then drained the tank and did the swapped the new carb . Got the fuel pressure lined out @ 7 psi . I am really happy with results although I didn't get to test Friday night due to a bent pushrod and broken rocker stud . I have no ideal what happened , went bang and lost #4 . Started with compression test which yielded 85# . Pulled valve cover and found this .
![]() Did a leak down while I had it down and all cylinders where low 90's at 100 psi. I had worries I got a head gasket or a valve , but I got lucky . A buddy of mine had a stud and we were able to pull the piece out of the poly lock . Bought 2 new pushrods and got it back together . Just kinda set the carb to the best running settings . Plans are to get it on a chassis dyno with an o2 or temporarily set one up and test at the drag strip . Pretty happy with the whole swap . Went up one heat range on plugs cause it was acting like it would load up a bit . That seemed to stop with hotter plugs . I added a good bit of initial timing also moving the curve to 20 with all the timing in by 2000 with a total of 36 . This took a lot of cam lope out . http://vid47.photobucket.com/albums/...ps178b8013.mp4
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 |
