Old 02-01-2015, 08:15 PM   #1
nolimitssjca
Front Drum Shoes - What am I Missing?
The engine in my son's 70 C20 finally gave up, so I pulled it and decided since I had unfettered access to the front end I would fix and refresh a few things while I was there.
Today I was replaced the brake hose, cleaned up the backing plate, put in new springs, cleaned the adjuster (you get the picture) then whammy, my drum won't fit over the shoes.
The adjuster is all the way closed (maximum space) figuring I would open it until I got it right.
I'm scratching my head because I know they work (same stuff I took off).
Any ideas?
nolimitssjca is offline   Reply With Quote
Old 02-01-2015, 09:13 PM   #2
beetle1960
beetle1960's Avatar
Re: Front Drum Shoes - What am I Missing?
new shoes or the one that were on it?
1953 Chevy 3100
1964 Chevy Impala
1966 Chevy El Camino
1970 Chevy C10 Fleet Long
1972 Chevy C10 Step long
1985 Chevy K10 Fleet Short
beetle1960 is offline   Reply With Quote
Old 02-01-2015, 09:46 PM   #3
cdowns
cdowns's Avatar
Push shoes into the cylinders (it might b easeir with the bleeder open)
Old 02-02-2015, 01:37 AM   #4
Tango59
If the plungers in the wheel cylinder came out that may be the problem. Take the top off the master cylinder and push the shoes in hard. Had to do that today. you'll still have to adjust the brakes tho.
Tango59 is offline   Reply With Quote
Old 02-02-2015, 02:15 AM   #5
nolimitssjca
Same shoes (only have a few thousand on them). The wheel cylinders did pop out and I had to pop them back. I'll look at that next. Thanks.
Old 02-02-2015, 11:49 AM   #6
michael bustamante
michael bustamante's Avatar
also make sure your adjuster is in the right place. i put it too high one time and fought it for hours
1967custom
michael bustamante is offline   Reply With Quote
