Disc brake conversion
Hi guys new here and I have a quick question. I was wondering what rotors and calipers are used on the conversions offered from CPP, ECE and others? I would like to purchase the spindles and I have a friend who has some new spare rotors and calipers from his 72 I can get for free. Just trying to keep the costs down, I tried searching here and other places with no clear answer. Thanks in advance Mike.
Re: Disc brake conversion
Mike, I purchased the kit that ECE sells. When I bought the 4/6 drop kit with the drop spindles I purchased the front brake disc conversion kit with it. Great kits by the way they supply everything you need. The rotors I keep with the six lug style because I didn't want to purchase new wheels at this point in time. The rotors, calipers, hoses, bearings , seals, dust plates, etc. all look like stock stuff that Napa or Advanced auto could supply you. I believe they told me at ECE just ask for parts from 1971 to a 1984 truck. You should be fine with the parts that you mentioned to save yourself some money. Rick
1970 C10 SWB |
#3 | |
67-72 parts collector,…
![]() Join Date: Nov 2002
Make sure the spindles you buy are the HD version and NOT the 81-87 Light duty version. Your buddy's 72 rotors will work fine on a HD spindle, because they are 1.25" wide.
Thanks Craftsman and lolife99 the info that helps greatly.
![]() Join Date: Nov 2001
Welcome to the board.
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White |
Moderator
![]() Join Date: May 2007
What year brake hoses are used? Are there any that bolt directly to the existing drum brake hard lines?
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
#7 | |
Direct bolt on.
Thanks for the welcome 67 CST swb.
