Ball joint removal
So I'm planning on doing my front disc brake swap on my 68 this week. What's an easy way to get very rusted cotter pins out of the castle nuts on the ball joints? I already broke one off. I'm guessing I could break them off and just force the nuts off the ball joints, but just seeing if there's an easier way. Thanks.
Re: Ball joint removal
Most of the time it is the way to go is to just screw the nut off and then drive out the center of the cotter pin if needed once the nut is off.
I have never had cotter pins that were rusted to that point & I've worked on some pretty old stuff. If the ends break off I would spray some WD40 on em & use a punch, screw driver or even a nail to push them through. I don't think it will be that tough.
1969 Chevy Long Fleet Custom C/10 (2nd owner) 1971 Chevy Short Fleet Custom C/10 (2nd owner) 2001 Chevy Silverado Ext Cab ![]() |
I am a Referee of life.
If you're having that much trouble with the cotter pins, you need to video the conversion. I'm predicting brand new cuss words.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
Oh you can bet that is absolutely going to happen haha. But I got to thinking, since I already have spindles and am replacing the ball joints, I can cut or torch a few things if necessary.
It seems like I read about heating up ball joints can cause the joint to blow up.
Don't know if you are planning it or not, but owning a ball joint press has its advantages. I bought the cheep HF one. I haves used if more for u-joints, but I'm glad I got it for the ball joint job on my front end.
1969 ![]() 2015 GMC 2500 Duramax (Daily Driver) 1999 Jeep TJ 2010 Harley Street Glide Check Out My Build!: http://67-72chevytrucks.com/vboard/s...d.php?t=617981 |
![]() Join Date: Jan 2013
I couldn't get mine out. I just cut the ends of the pin off, and used a 2ft breaker bar and it wasn't a big deal at all. I spent more time trying to drive them out than I did just forcing it with a breaker bar haha.
Josh 72 C10, 350/2004r, Porter Steel Pacs, and 40+ years of leftovers from strange POs... |
![]() Join Date: Mar 2012
vice grips / hammer and some lube it is just a weak cotter pin
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks ![]() |
Cotter pin extractor
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
![]() Join Date: Dec 2012
if the pins are that rusted, loosen the nut a couple of turns then drive on a bumpy road for a bit to break the tapers loose from the spindle.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11. 1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9 |
