Old 01-28-2015, 08:34 PM   #1
Nodnarb76
Nodnarb76's Avatar
Bumpers sagging a little
Do I need new brackets or can they be adjusted?
1987 R20 Suburban LQ4/4L80e swap: http://67-72chevytrucks.com/vboard/s...d.php?t=693824
Nodnarb76 is offline   Reply With Quote
Old 01-29-2015, 07:33 PM   #2
acesound
Re: Bumpers sagging a little
I think that's a very common problem for many of us, I have same issue, free bump 'cause I don't have an answer. I think disassabling and iron back the bumper supports to original angle and height will be a good option.
acesound is offline   Reply With Quote
Old 02-03-2015, 11:54 AM   #3
crashz
crashz's Avatar
You can try loosening up the brackets at the frame and adjusting it, but I think they might be tweaked a little. They might have seen a minor bump or two.
I would try pulling the brackets off of the truck and massaging them with a BFH to straighten them, but I like to hit things with hammers
2012 Chevy 2500HD, 6.0L, 6spd auto, 4x4, ECSB
1987 GMC V3500 Dump, 6.2L diesel, TH400
1983 GMC K2500 - awaiting its restoration and Cummins swap.
crashz is offline   Reply With Quote
Old 02-03-2015, 06:48 PM   #4
68Timber
I know the pieces fit
68Timber's Avatar
Those have done a little pushing is all. As mentioned, loosen and adjust or tweak the mounts to get them to line up. I'd take that screw out of the side molding too and fix it before it rusts.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
