Old 02-03-2015, 06:14 PM   #1
65standard
65standard's Avatar
Drum/drum brakes???
Is my 1970 C20 manual drum/drum brakes supposed to have a proportioning valve? And if I add a power booster, do you use a proportioning valve?
Tony Nicholas @ Midwest Metal Masters
1953 Chevy 3100 392 Hemi w/727 & 9” Ford
1985 Chevy C/10 6.0L 4L80 373 locker
65standard is offline   Reply With Quote
Old 02-03-2015, 06:51 PM   #2
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: Drum/drum brakes???
Nope. The prop. valve is to increase line pressure to front discs, as they require more than drums. Same with a power booster -- no prop. valve req'd with drum/drum setup.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 02-03-2015, 07:19 PM   #3
65standard
65standard's Avatar
Thanks for the info Mike
Old 02-03-2015, 07:47 PM   #4
FirstOwner69
FirstOwner69's Avatar
Correct. BUT, he does need a distribution block if for some reason he doesn't already have one.
FirstOwner69 is offline   Reply With Quote
Old 02-03-2015, 08:10 PM   #5
65standard
65standard's Avatar
I guess that is what was cut out of the brake system when the truck lived in the junkyard. Any clue as where I can get one of these? Look like a chevy dealer only part. Then again, I doubt a dealer would be able to get a 45 year old part.
Old 02-03-2015, 09:27 PM   #6
FirstOwner69
Check out the parts board for trucks being parted or buy new from Inline Tube
http://inlinetube.com/Prop%20Valves/PR-112.htm
Maybe this ad on the parts board... looks like he's not responding though.
http://67-72chevytrucks.com/vboard/s...d.php?t=658475
Old 02-03-2015, 09:47 PM   #7
65standard
65standard's Avatar
Thank you, I appreciate the links.
Old 02-03-2015, 10:14 PM   #8
FirstOwner69
It looks like you may also need the bracket that holds the distribution block as shown in my picture. However, it may be there and a bit bent. Hard to see in your pic.
Old 02-04-2015, 02:10 AM   #9
jocko
jocko's Avatar
LMC sells them. Over $200 last time I bought one though... Distro block also provides the signal for your dash brake light - indicates when one circuit has been lost - safety feature.
Old 02-04-2015, 07:27 AM   #10
Don Quixote
Don Quixote's Avatar
www.classicparts.com has the distribution blocks for drum/drum for $80. They're out there and they're not expensive. I recently replaced mine.
Rocinante: 1972 GMC C25, 292, SM465, 14 bolt, power nothing, 440k and still handles my PCS moves
Jorge: Kia Roller-skate with lots of buttons for the wife
Wovoka: 2017 Indian Chief Vintage, better on gas but not much
So far, this is the oldest I've ever been.
Don Quixote is offline   Reply With Quote
Old 02-04-2015, 08:47 PM   #11
RodnRudy
RodnRudy's Avatar
I've got a distribution block laying on the floor of my garage, took it off my running driving 68 C10 truck. Upgrading to disc brakes so I've got all new stuff. It's free to you if you PM me your address.
Phil
RodnRudy is online now   Reply With Quote
Old 02-04-2015, 09:01 PM   #12
65standard
65standard's Avatar
Thank you Phil, much appreciated. I'll PM you.
