Re: Not sure what to expect, advice?
Bear in mind that rubber age hardens, particularly if it is not kept immersed in oil/fluid.
So watch out for the rubber parts: - the brake master cylinder. There is a rubber cup on the end of the piston that will harden if not exercised. This results in the brake pedal slowly falling toward the floor as it is held. - the brake slave cylinders. - engine, transmission and power steering seals. These tighten up as they harden and then don't seal. They can be loosened up with a good seal conditioner that replenishes the lost elastomers, such as AT-205. Careful, though. Some seal conditioners act to partially dissolve the rubber, and that is not good. Get the good stuff. One bottle in the engine oil. One in the trans. Part of a bottle in the P/S pump. - Of course you are going to need new windshield wiper blades. Easy to forget until it rains. - Something to replenish door and window seals. If anybody has a good suggestion here, please pipe up. Again, something that is easy to overlook until it rains.
Rich Weyand 1978 K10 RCSB DD. |
| Bookmarks |
