Old 02-05-2015, 12:34 PM   #301
Advanced Design
Advanced Design's Avatar
Re: The "Frankenstine" build;
In the house?...Love It!!
Advanced Design is offline   Reply With Quote
Old 02-05-2015, 08:58 PM   #302
T-P Auto
AD;
When your single you can get away with doin things in a nice warm home.
Do you know of any way to get old paint of the rubber around the wing windows ? ?
Will try to get the wing windows installed tomorrow if I can stay on my leg that long.
Going to try to do some body filler in the house also. (pic)
T-P Auto
T-P Auto is offline   Reply With Quote
Old 02-05-2015, 09:07 PM   #303
T-P Auto
Here are the pic;
Two of the wing windows
four of the driver side front fender
T-P Auto
Old 02-05-2015, 09:08 PM   #304
T-P Auto
OOPS ! !
one more
Old 02-05-2015, 10:35 PM   #305
Advanced Design
Originally Posted by T-P Auto View Post
AD;
T-P Auto
Tim I am not sure of a good way to remove the paint so I will defer to someone that does.
And about working in the house...I did use an older oven in the basement to heat cure some paint on exhaust manifolds once...and sanded on a 1940 Willys fender in a hotel room.
Stay warm!
Old 02-06-2015, 02:26 AM   #306
T-P Auto
AD;
With try to take out the small dents
it is nice to just take some time in between,
Just working a small area at a time.
Will try to get the wing windows in tomorrow.
T-P Auto
Tim:
Old 02-06-2015, 04:44 PM   #307
T-P Auto
Hello Everyone;
Well got to the shop today.
Got the air deflectors installed on both windows. (pic)
Got the DS n PS wing windows installed all so. (pic)
You can still see the green n blue paint on the rubber around the wing window glass.
The next thing I will try to do is get the wing windows tinted ! !
Hope everyone enjoys the pics
T-P Auto
Old 02-06-2015, 08:40 PM   #308
flashed
Im still watching your build just have had little time to post lately ,my work is running me ragged .
flashed is offline   Reply With Quote
Old 02-06-2015, 08:43 PM   #309
Advanced Design
Tim that was a good day in the shop!
Old 02-08-2015, 08:20 PM   #310
T-P Auto
Hello Everyone;
well got the 1' spacer under the cab yesterday.
made some templates for the wing windows,for tinting them)
Got the rear window n side windows tinted today,(pics)
Still letting them dry ,then will clean the tint up.
Will try to get the power window motor assy's on tuesday.
have a Dr's appt in Alb tomorrow so will not get to work on the truck.
Got the DS fender on yesterday all so.
Working on the PS fender the next few days.
T-P Auto
Old 02-08-2015, 08:45 PM   #311
Clay54
Hey Tim, in post #307 you have pictures of the vent windows installed. They look good and I was wondering if you refabed them and if so what kind of a pain in the butt was it? Keep up the good work. Clay
Clay54 is offline   Reply With Quote
Old 02-08-2015, 09:14 PM   #312
T-P Auto
Clay54;
My truck had the full window set.
I come across the wing window set.
I only had to do very little trim work to get the wing window to set in the window opening.
I going to try n put power window motors in for the side windows.
I'll try to get a close up of the trimming I had to do.
I just like the 2 part window so much better then the 1 part window.
-- (OLD SCHOOL) --
T-P Auto
Old 02-08-2015, 11:11 PM   #313
Clay54
Thanks for your quick response. I have been trying to respond to you but the server is too busy and won't let me in. Old school or not, my '54 has vent windows and I want to keep them. Just thought you might have rehabed yours and knew how bad a problem it was. Thanks, Clay
Old 02-09-2015, 07:35 PM   #314
T-P Auto
Hello Everyone;
Got to the Dr appt in Alb today.
That is an all day trip.
left at 730 am just got back in town at 330pm.
Well got the cast made today,
Will go back next Monday to get it fitted
Then the next Monday will have the 1st of 3 NEW socket.
Hopefully these will not rub my leg.
So for the next few week will wear my older socket n let the leg heal up some more.
So did not get anything done on the project today.
Then there is always tomorrow .
Old 02-09-2015, 08:05 PM   #315
oldman3
oldman3's Avatar
Tim, glad they are getting you fixed up, take care...Jim
oldman3 is offline   Reply With Quote
Old 02-09-2015, 10:03 PM   #316
Advanced Design
Me too Tim. Hope you have some good time in the shop tomorrow!
Old 02-12-2015, 09:14 PM   #317
T-P Auto
Hello Everyone;
Well got to work in the shot today;
Was COLD here yesterday;
Got up to like 50 today;
Been working on the dents in both fenders; (pic)
Got both fenders mounted on the cab n fitted to the hood; (pic)
Got the front radiator support redone n fitted to the fenders;
Tomorrow I will try to get the holes drilled for the radiator mounts to the frame. (pic)
Will need to move the DS of the hood forward like1/16 of inch;
So that the hood clears the cab when opening.
Got the front radiator support set in the frame also. (pic)
Got the radiator at a shop to turn the lower outlet stright;
In come out at like a 45deg angle;
Don't have much space in the front of the motor. (pic)
Once I get the radiator set back in then I will have to make some type of
brackets to hold the radiator in place.
Still have not started on the power window set up.
Once I get the fenders n hood ready to paint then I plan to paint the wing window frame at the same time.
Will be several pic to follow.
T-P Auto
Old 02-12-2015, 09:18 PM   #318
T-P Auto
More pics
T-P Auto
Old 02-12-2015, 09:45 PM   #319
flashed
Looking good .
Old 02-12-2015, 09:48 PM   #320
Advanced Design
Wow, you had a productive day Tim!
Old 02-13-2015, 07:30 PM   #321
T-P Auto
Hello Everyone;
Well spent the morning with my sister(her b-day)
I took her to lunch n give her a valentine box of choloates.
Pulled the (OLD) grill out n got it dis assy; (pic)
It is bent up real good
So going to see what part of it that I can use to make a grill for my front end.
With the cab so low n the fenders NOW set right;
I don't need all that much grill.
As you will see in the pics it is in several pieces HOW .
T-P Auto
Old 02-13-2015, 07:32 PM   #322
T-P Auto
More on the grill;
T-P Auto
Old 02-14-2015, 05:20 PM   #323
T-P Auto
Hello Everyone;
BEAUTIFUL Day;
Got to work on the project today.
Got the DS n PS wing windows painted. (pic)
Worked on the front grill.
Had to try to work out some of the dents.
Got is as best as I could.(No body man)
I can only run two of the long bars on the grill. (pic)
Will use the ends of the other bars to make it look better.
Will paint the bars the same as the body.
The inside bars will be the same as the dash( lighter color)
Still have to get some self tappers (3/8) to mount the side radiator supports in with.
Still need to work the front of the hood some more.
T-P Auto
Old 02-16-2015, 10:43 PM   #324
Advanced Design
Good work with the grill bars Tim. You are making good progress. Vent windows came out well too.
Old 02-17-2015, 08:30 AM   #325
T-P Auto
AD;
I'm still not a body person.
I had to do some work on the grill bars.
Working to make the last two btm bars work also.
Thank You for the kind words.
Will try to get the wing window cleaned up n the tint installed.
T-P Auto
