#51 | |
Re: My suburban's Twisted Little Sister
Yesterdays progress was just welding some 2X4 frame curves. Today I decided my daily driver needed some work so we changed the head lights to LED then we used "GMC Sub4X4" idea for LED taillights http://67-72chevytrucks.com/vboard/s...d.php?t=623681. Makes quite a difference.
Dale ---------------- My suburban's Twisted Little Sister http://67-72chevytrucks.com/vboard/s...d.php?t=655167 |
#52 |
Nice! Where did you get the headlights?
#53 |
![]() Join Date: Mar 2013
Frame and burb are looking good!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
#54 |
Thanks Guys
The headlights came from the local truck and tractor parts supplier. I haven't decided if I like the look of them yet. They stick out about 1/2 inch.
#55 |
Here's Friday's work. One rear frame rail welded and ground and one just tacked together.
#56 |
Yesterday's snow storm kinda slowed things down today but we did get one rear frame rail mocked into position.
#57 |
We got a bunch done in last couple of days. First we welded on the other rear frame rail. Second we made some boxing plates for the rear corners. Next we put in two angle braces for the rear frame rails.
#58 |
Then today we got some 1/4 x 3 flat bar drilled thee mounting holes. We bent the ends in the metal bender. The last picture is the bracket tacked in place
#59 |
![]() Join Date: Aug 2013
#60 | |
Friday we finished the welding and then used the cherry picker to lift the rear suspension into place
#61 |
Looks good
63 1ton Paneltruck build: http://67-72chevytrucks.com/vboard/s...d.php?t=627721 Instagram: jaked937 |
#62 |
We made a little progress the last couple of days. First we made some brackets for the batwing crossmember and got them welded on. We aren't finished with them yet. Then we cut out one of the shockwave brackets.
#63 |
![]() Join Date: Jul 2012
Very nice brackets. Did you use a plasma cutter?
#64 |
Thanks A.D. I just used a cut off wheel in a die grinder and a sanding disk.
We made a spacer for between the lower shock mount and the shockwave bracket. The we made upper and lower brackets for the shockwave
#65 |
Beautiful work, I will be following this one.
Dave |
#66 |
Thanks Dave
Here's my picture for today. Hot rodding in the Great White North
#67 |
Enjoy your truck
I just found your build thread. Very interesting for sure.
My in-laws owned some property in Dresden about 25 years ago and they planned to build out there. All I remember is that Dresden seemed like the middle of nowhere (no disrespect intended). Are both your Burbs Canadian in origin? Greg.
1 Corinthians 10:13 1963 Chevrolet 1/2 ton 2010 Camaro SS/RS 2014 Jeep Grand Cherokee 2016 Jeep Cherokee |
#68 |
Awesome build so far!!
1963 GMC swb sbw 5.3/4l60e porterbuilt From middle Tennessee 60-66 hood for sale or trade for bench seat rust free nose little pin holes on top message for more details.. |
#69 | |
Thanks cheesee
#70 |
Greetings from Cambridge, I am in awe as much as I am perplexed at what you are doing. Really looking forward to seeing this one progress!
Craigerrr My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709 |
#71 |
Another job of someone knocking it out of the park, some talent being displayed here.
#72 | ||
![]() We had to make a small notch for the driveshaft. Next we got the upper and lower shockwave mounts for the rear tacked in place. Then we got started making bump stop brackets.
#73 |
Nice work! You move fast!
#74 |
i need a set of replacement burban frame horns welded on, you should cross and help me out??? i'll have some timmies(tim hortons) wait'n for ya...
#75 | |
Thanks AD.
Today we got a bit of welding done. Then finished the bumpstop brackets and tacked them in place. Also started the rear frame turn down
