Old 02-08-2015, 12:10 AM   #4
tll74
"Junkyard Dog"
tll74's Avatar
Re: WTB..I6 Fan Shroud
Originally Posted by Todd68Chevy View Post
Is it different from the metal top shield that was used on the 6 cyl, 3 speed trucks? I have a couple from the 6 cyl. stick trucks.
The I6 automatic trucks all have a fan shroud and use the 28 1/2 wide radiator. Your upper covers would be stock on a stick truck.
Originally Posted by PICKMUP View Post
Most 6cyl had the small metal fan "guard", but some HD models had a fan shroud like the SBs. I have run the SB shroud by installing the wider V8 radiator & mounts...then just bolt in the SB shroud. Make sense?
Yeah that would work but the sbc non AC shroud (5.250 deep) is 1" deeper than the 6 cylinder which is 4.250 deep. The problem I see here is the fan would be to far into the shroud. To be ideal the fan blade should be half in and half out of the shroud. Maybe a shorter spacer would make this combo work best.
I'm not using it for a I6 application.
I have what I'm looking for but I need another. I'll post some pics if it soon.
Thanks, Tom
72 C-10 Cheyenne Super LWB, Vortec 427,TH700, 3.73 posi, tach, tilt, AM-FM,Frame off in process.
http://s289.photobucket.com/albums/l...t=7eae161e.pbw
88 Monte Carlo SS bought new only 10k miles.
73 Chevelle SS 454 had since high school.
74 Camaro Z28 350 AT numbers matching, Black on Black.
73 El Camino SS 350 4sp.
70 Chevelle SS 396 4sp, number matching with LS6 454
69 Chevy C30 Car Hauler
86 K20 383 4sp 4" lift frame off restoration.
http://s289.photobucket.com/albums/l...t=1b1082d3.pbw
tll74 is offline   Reply With Quote
