02-06-2015, 10:59 PM | #1 |
283 Double Groove Water Pump Pulley
I have a 1965 C10 Fleetside with a 283 and I am in the process of installing a factory air system I recently picked up. I have found a double groove crank pulley but I am having trouble finding a double groove water pump pulley that is the same diameter (7") as my original single groove. Were 7" diameter double groove water pump pulleys made? Everything I can find for a 283 are 66.4"
02-06-2015, 11:33 PM | #2 |
Re: 283 Double Groove Water Pump Pulley
Having just went through this myself, I can tell you that I too was unable to find a double groove for my 283 in the same diameter as my old single. I went wtih the 6.6 which is still made by G.M. The extra r.p.m on the fan will probably be good for the a/c anyhow.
02-07-2015, 01:37 AM | #3 | |
I have a nice built 283 that I wanted to install in a truck with the dealer installed factory model AC unit from My 66' GMC parts truck which had a big block 351E V6. Glad to hear it is possible.
Projects: 65' Chevy C10 swb (rebuilt chassis) 65' Chevy Panel swb 64' Chevy C30 flatbed "above" 80' C30 "beneath") Parts: 66' GMC 2503 & 65' GMC I1500 |
02-07-2015, 01:54 AM | #4 |
Thanks for the replies. I will probably just go with the 6.6".
02-07-2015, 10:08 AM | #5 |
I bought a set of air pulleys I am not using and I believe they are 7", I will check today.
02-07-2015, 10:53 AM | #6 | |
02-07-2015, 11:01 AM | #7 | |
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
02-07-2015, 12:34 PM | #8 |
LT1 Burb let me know if you find them. I would be interested in the water pump pulley.
02-08-2015, 02:15 AM | #9 | |
60-66 Nut
A 283 is a small block just as a 327 or 350 for that matter. Most all small block parts are interchangeable to a certain degree
02-08-2015, 02:31 AM | #10 |
Captain is right, and that certain degree involves water pumps and pulleys as well as few other things so take note if the water pump has a long snout or a short snout and get the pulleys for your particular style. The various pumps and pulleys will still bolt on... but the stickler is making sure they line up correctly.
