Old 01-29-2015, 11:45 PM   #1
jbassC10
Drop question? 1 inch down on left compared to the right ?
My left front side drop is about 1 inch roughly lower than the front right side.
I've measured this at different locations to make sure it was just a hair higher elevation in the parkin lot then or over there etc. and the same distance is there.
What do you think the problem is guys?
(there's no weight in the bed over balancing on one side either)
Thanks for your time guys!
~Tyler
(I've checked the front drop springs and they seem to completely be sitting correctly in the spot of the front A-arms...in other words, not turned a bit this way or that way since there's stop point.)
[It's not causing any driving difficulties or notices at all, it's just by vision is the only notice]
jbassC10 is offline   Reply With Quote
Old 01-30-2015, 12:01 AM   #2
leddzepp
Moderator
leddzepp's Avatar
Re: Drop question? 1 inch down on left compared to the right ?
The infamous Chevy lean. Forty years on the road and the frame is probably tweaked a bit.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 01-30-2015, 12:06 AM   #3
SS Tim
SS Tim's Avatar
Did you measure the ride height first?
From the ground or the center of the wheel to a repeatable fender lip?
Did you verify the free height of the new springs as being equal between left and right?
Are your cab mounts good? Lowering could have made a pre existing condition more noticable. Is the frame known to be square?
SS Tim is offline   Reply With Quote
Old 01-30-2015, 12:07 AM   #4
bovey
bovey's Avatar
This happened to me as well, in my case a spring had sagged. Measure in two places like the centre of the wheel wells and a frame location - pick bolt holes for reference and make sure you are on flat ground.
Targa Truck The first truck in Targa Newfoundland.
https://www.facebook.com/targatruck
Build thread:http://67-72chevytrucks.com/vboard/s...d.php?t=625874
Action Video: https://www.youtube.com/watch?v=ru3i7lPP5EA
bovey is offline   Reply With Quote
Old 01-30-2015, 12:27 AM   #5
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
Take a look at the cab supports and mounts. Left side usually wears out before the right, especially if the PO was a big guy...Might take a look at the core support mounts as well.
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 01-30-2015, 02:05 AM   #6
jbassC10
Oh wow! Awesome guys!
The measuring tips will be on my To-List for tomorrow!
...i'm excited to see what the measurements are because all the cab supports from being under it a numerous amount of times are still good. But hey, there's no problem with checking again!
Thanks so much guys!
~Tyler
Old 01-30-2015, 09:10 AM   #7
cdowns
cdowns's Avatar
normal on about 100% of old chevy trucks
Old 01-30-2015, 09:37 PM   #8
hotrodder
Thumbs up Re: Drop question? 1 inch down on left compared to the right ?
I agree with the frame sag. I have built five trucks and everyone of them had the probem. I do body work so I have access to a frame machine to bring the frame back to specs. If you don't want to go to that much trouble, you can get a spring rubber that goes under the spring to raise the corner. I think O;reillys, or Advance auot parts has them.
hotrodder is offline   Reply With Quote
Old 01-30-2015, 09:45 PM   #9
Lee H
Lee H's Avatar
How many miles on your dropped suspension?
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have all original numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 01-31-2015, 02:00 AM   #10
mechanicalman
~Tyler
Whatever you do, carefully consider exactly what is causing this and do everything possible to correct only the root cause and if you decide to alter something else to compensate think real hard about that.
Put it on nice level concrete and start measuring. If the springs are the problem, then you should be able to detect a difference from side to side from the bottom of the frame to the pavement. If the frame is level on the front, then it's probably something else.
That being said, if it is springs, aforementioned spring spacers are the best way to go.
Also, consider the condition of the a-arm bushings. Worn, stiff bushings can alter ride height. Maybe get out the grease gun.
mechanicalman is offline   Reply With Quote
Old 02-06-2015, 12:43 AM   #11
jbassC10
Hey, I've only got maybeee 500 miles on the drop. So the springs should be good to go if that's what you were wonderin.
I'm thinking a spacer probably in the front...will see!
Old 02-06-2015, 12:45 AM   #12
jbassC10
Hey!
Yeah I will deffently keep that in mind: What happens here could move something over there.
And I haven't measured the frame or body in certain places, but that's on the to-do list for here soon!
I'm having a feeling, a spacer(s) is probably gonna be the fix.
Will see I guess!
Thanks for your time!!
~Tyler
Old 02-08-2015, 05:36 AM   #13
jbassC10
Here's the measurement from the center cap on the front wheels......
I also measured the frame front and back and it's all really close for being 45 years old! lol
.....What do you think guys? Would it be stupid to put only one spacer in the front to level it out??
Good ideas guys??
Old 02-08-2015, 05:37 AM   #14
jbassC10
Sorry the photos didn't rotate correctly. And yes the photos are tough to tell exactly the difference, but were looking about an INCH down on one side than the other......
Old 02-08-2015, 08:46 AM   #15
NC_John
NC_John's Avatar
Mine sat uneven when I got it. 1" down on the front drivers side corner. Thought it was just tired parts. Changed out all the suspension (springs, shocks) etc... New cab mounts, new rad support mounts.... Still leaned.
Took it to a frame shop and had everything squared back up,and set to factory zero. Still leaned. The body panels and body lines are perfect so we agreed the frame is indeed straight.
So I said "f*ckit" and cut my passenger side (brand new) coil spring down to match and level it. Perfect.
But now, a few months later, my passenger side is too low.
I give up.
1970 C-10 LWB "Blu"
Instagram (current build pictures) 70_nc_c10
NC_John is offline   Reply With Quote
Old 02-09-2015, 03:30 AM   #16
jbassC10
I give up.
Oh great. hahaha
Well smoke, Im lost now. haha
I'm gonna try the one side spacer first and play the game from there I guess.
Gee'z ..worst news for the day. haha
But really thanks for keeping me updated on what happen to you ole C10
NIght man!
Old 02-09-2015, 07:56 AM   #17
Mr Handy
Mr Handy's Avatar
Mine leans to the drivers side about an inch as well. It made me think the frame was twisted. Crawling around under the truck one day I noticed the core support mount on the drivers side was completely gone... metal on metal... that makes up the 1" difference in the fender lip and also why the bumper looks tweaked... bumper is fine its the gill that's low. New mounts should get everything lined up.
Mr Handy is offline   Reply With Quote
Old 02-09-2015, 08:32 AM   #18
Dustmaker65
Dustmaker65's Avatar
Good ideas guys??
Tyler, by looking at your two pics, you have a good 1/2 inch difference from your measuring point and your rim edge... one is shy of 12 inches and other is strong of 12 1/2 inches.
Jimmy
Dustmaker65 is offline   Reply With Quote
Old 02-09-2015, 08:40 AM   #19
Ironangel
Ironangel's Avatar
Well according to your tape, your only a 1/2" inch down...That phantom can be spread out in 40+ years of existence...It's an old truck, not an Acura...A 1/2" can be in the body panels, sag in the cab supports and sheet metal...It can be in the new springs, have you swapped them? It can be anywhere, and everywhere..."just sayin" PS...When you get it right, it's going to be down again as soon as you get in the truck...
"Two Seventy Two's"
02 3/4 ton Express
Old 02-19-2015, 03:49 AM   #20
jbassC10
Hey! Thanks for writing on here for me...and yea; AGE is probably where its at. lol And to answer your question: Yea I've put the new drop springs in, so there new. And the body mounts seem good to go! So I'd say...it's just the years on the body all the way around I'd guess! lol
Old 02-19-2015, 09:03 AM   #21
72MARIO
72MARIO's Avatar
My suburban is a 1" lower on driver side when its aired out .......
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 02-19-2015, 10:25 AM   #22
jjzepplin
jjzepplin's Avatar
Oh just drive that good looking truck already!
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 02-19-2015, 11:43 AM   #23
Longhorn 70
Longhorn 70's Avatar
Have you measured the difference in spread between the spring seat and upper AFrame? That is how I found a spring problem on mine years ago.
Spring was lifting one side more than the other. it was 3/4" difference which made a difference on the truck that was visible.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11.
1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar
And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9
Longhorn 70 is offline   Reply With Quote
Old 02-19-2015, 12:09 PM   #24
NC_John
NC_John's Avatar
wouldn't new springs eliminate that?
1970 C-10 LWB "Blu"
Old 02-19-2015, 12:10 PM   #25
Fatherof3
Fatherof3's Avatar
This
65 C20 292 4spd 4:56 Eaton HO52
Fatherof3 is offline   Reply With Quote
drop
