Old 02-06-2015, 11:39 PM   #1
AzCountryman
AzCountryman's Avatar
while the oil pans off.....
Have to put a new oil pan on so why I have it ripped off is there anything else I should do?
Ordered a new oil pump.
Stock 327 as far as I know it has never been rebuilt. I have had it 10 years.
Are you a collector? If so come check out Collectorsunleashed.com Doesnt matter what it is we have a spot to show it off.
http://www.collectorsunleashed.com/#
AzCountryman is offline   Reply With Quote
Old 02-07-2015, 12:00 AM   #2
AcampoDave
AcampoDave's Avatar
Re: while the oil pans off.....
I would do the timing chain and take a good look to see if the freeze plugs are rotting out in the block too.
AcampoDave is offline   Reply With Quote
Old 02-07-2015, 07:39 AM   #3
vince1
I think I'd pop in some new bearings and seals too as they don't cost much.
vince1 is offline   Reply With Quote
Old 02-07-2015, 07:44 AM   #4
vince1
Oops, with engine still in vehicle ignore the above.
Old 02-07-2015, 11:57 AM   #5
Chevy Fleetside
Chevy Fleetside's Avatar
Rear main seal?
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 02-07-2015, 01:12 PM   #6
65 C20
Originally Posted by Chevy Fleetside View Post
Rear main seal?
X2 good idea.
65 C20 is offline   Reply With Quote
Old 02-07-2015, 01:35 PM   #7
jtrichard
roll in a set of rods and mains.....rear main seal and i would seriously consider pulling the front cover and do a new timing chain (unless it has a roller type chain in it)
jtrichard is offline   Reply With Quote
Old 02-07-2015, 04:35 PM   #8
Mr Bear
Rod bearings. Main bearings. Rear main seal. Front timing cover seal and balancer sleeve. Timing chain and gears. Oil pan gasket with the bolt pressure spreaders. Drill and tap crank snout for balancer retention bolt and washer (probably have to pull radiator for this job). Oil pump and R&R pickup and screen. Its all doable from underneath. This much work, you best validate the motor is worth it with a compression test, wet and dry. If both are good, tear into it. If not, time for rings and/or valves so do the entire motor.
Mr Bear is offline   Reply With Quote
Old 02-07-2015, 08:34 PM   #9
AzCountryman
Lol just rebuild the engine huh. It runs good. Blows a little blue smoke when I fire it up. My dad was saying we should change the bearings while the pans off. Have to put a new radiator in to because I noticed the cardboard has antifreeze on it so looks like it has a small leak.
Old 02-07-2015, 08:42 PM   #10
Mr Bear
Yep. Sounds like you should pull it
Old 02-07-2015, 09:05 PM   #11
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Blue smoke on start up sounds like valve seals need to be done.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 02-08-2015, 02:09 PM   #12
61K10
61K10's Avatar
put a pan on and new o-pump and drive it--rebuild it later if need be.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 02-08-2015, 04:27 PM   #13
AzCountryman
About the best plan I have heard yet. All these years I have owned it has never been down for more then a day. Now it's been like 5 months.....miss that exhaust sound.
