Old 02-08-2015, 02:57 PM   #1
Fakeshemp73
Fakeshemp73's Avatar
Frame clean up...will this come back to bite me?
Hello,
So I'm pretty new to the forum and I can usually find what I'm looking for when using the search so I haven't had a need to ask any questions yet but I'm sure this will be the first of many. I'm in the process of cleaning my frame and I'm taking it down to metal and and will be using VHT chassis paint. So I just want to know if I'm being to anal when getting all the little bits around rivets and other tight spots when taking it down to the metal? If I don't get every nook and cranny will it bite me down the road with rust issues? first time posting pics so hopefully they show up. Let me know your thoughts. I don't mind doing the work to get it totally clean but if I don't have to then I can move along a little faster. Thanks for any input.
John
Fakeshemp73 is offline   Reply With Quote
Old 02-08-2015, 03:11 PM   #2
Mock1
Re: Frame clean up...will this come back to bite me?
Unless its greasy, oily, or a loose rivit I wouldnt worry about it. Your not goin to get paint between the mount and the frame, so I ont think there will be an issue... in your lifetime anyway.
I didnt even clean my chassis other than pressure washing. But I used rustoleum and it sticks to rust better than clean steel. Doesnt VHT mean Very High Temp?
I thought that was just for headers, and had to be heated to cure.??
I just gotta get out here and do it, why?
Cause nobody will do it for me...
Mock1 is offline   Reply With Quote
Old 02-08-2015, 03:37 PM   #3
mgchevyparts
mgchevyparts's Avatar
I would have had the frame sand blasted, cost about $150
Shops here will sand blast and powder coat the frame around $500
1957 CHEVY 1/2 TON SHORT BED
1940 FORD 1/2 TON SHORT BED
mgchevyparts is offline   Reply With Quote
Old 02-08-2015, 03:56 PM   #4
Fakeshemp73
Thanks for the info...The VHT is normally a high heat paint but the roll bar and chassis paint is just for this kind of application I believe. I tested it on one of the crossmembers and it seems to hold up pretty good.
http://www.vhtpaint.com/products/rollbarchassis/
Old 02-08-2015, 04:02 PM   #5
Fakeshemp73
Yep, I really thought I wanted to do it by hand and say *I DID THIS ALL BY MYSELF* And now I'm to deep into it to turn back. Never again though.
it has kicked my rear-end for a month now.
Old 02-08-2015, 04:52 PM   #6
65standard
65standard's Avatar
You should be able to clean up those late few spots with a wire wheel on a small 4 1/2" grinder.
Tony Nicholas @ Midwest Metal Masters
1953 Chevy 3100 392 Hemi w/727 & 9” Ford
1985 Chevy C/10 6.0L 4L80 373 locker
65standard is offline   Reply With Quote
Old 02-08-2015, 05:03 PM   #7
Fakeshemp73
Yep, The 4 1/2" grinder has been my main tool with a 18 volt drill for some of the tighter spots. just wasn't sure if it was necessary to hit all of it or if it was overkill. I've been doing just that as far as getting the smaller spots so far but its been a tedious process.
1970 C10
4.5/6 drop from ECE
Body off restomod that seems to be never ending.
Mama Tried...
