![]() Join Date: Dec 2008
Air Ride Troubleshooting
Looking for some help. Without going into a lot of detail. 72 C10 Air Ride Tech. set up. No issues truck sat for 2 months take it out to drive and noticed it sat lower. Not remembering the settings (First Air Ride truck). I went to go raise it and things went south from there. Compressor continued to fill the right rear air and really had no pressure to little up front. so I kept bleeding down the back back bag getting truck home. Then noticed Compressor would not shut off so I disconnected the battery. I then noticed a leak coming from the exhaust side of the compressor. This emptied the whole system. Looking for help in where to start or what may have caused this to come on. Apologize for the winded explanation.
Thanks in advance!! Any input is valued. |
Re: Air Ride Troubleshooting
Take some pictures of your air management and specs if you can.To me sounds like your right rear valve had a leak or stuck open.And the compressors should kick off once the tank pressure switch tells it to but with a stuck valve it won't kick off.
I will do that.
Thanks |
Sounds like a peace of dirt on the valve seal. It you go back and forth multiple times with the up and down button it will blow the dirt out and should be fine.
You can hold up and down at te same time it'll continuous flow and hopefully move whatever (Teflon probably) out of the way. Mine has done that before, right rear wouldn't quit trying to fill had to burp it the whole way, at the same time my amp kit shorted and was getting continuous power, the **** was filling with the car off and key out.
#6 | |
hth
'82 C-10 SWB / C'd, Z'd, Body'd and Bagged / Shaved firewall, wiper cowl, drip rails, stake holes and tailgate/ 20" & 22" Milanni Voodoo '81 C-10 SWB Parts Truck IRC - http://webchat.snoonet.org/#baggedtrucks |
