Old 02-07-2015, 12:25 PM   #26
v30crewcab
v30crewcab's Avatar
Re: one ton 4X4 death wobble, what have you done to cure it?
I run springless adjustable caps on my truck. works great. if they get a little loose, I can tell when I hit bumps in the road, it feels a little funny in the steering wheel. time to retorque them. only had to do it once so far.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
Old 02-09-2015, 01:57 AM   #27
cmax87v3500
cmax87v3500's Avatar
Ive had death wobble in two k30's either mt dad or I have had. Both times it was king pins. If you don't mind straying away from stock you can do a spring eliminator kit, otherwise just get either GM replacement parts (depending on if they are available) or a high quality aftermarket rebuild kit and it'll be good to go. I would recommend keeping the big cast caps instead of the stamper metal one some kits come with. The previous owner of my 87 v30 did them and put the stamped one on there and I wish I had the factory one back. My .02
1987 GMC V3500 Sierra Classic
cmax87v3500 is offline   Reply With Quote
