Old 02-05-2015, 12:46 PM   #1
Chevyc10572
Chevyc10572's Avatar
frame rivets size
What size are the rivets in the frame
1970 chevy short box c10 factory 402 big block with AC
2008 chevy silverado regular cab short bed lowered
1990 454ss 52,000 miles 5/6 drop
Chevyc10572 is offline   Reply With Quote
Old 02-05-2015, 05:11 PM   #2
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
Re: frame rivets size
In between 3/8 & 7/16. There is size between them that is a perfect match, but isn't made anymore. I am drilling my holes for 7/16 rivets in the crew frame.
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 02-05-2015, 07:53 PM   #3
Tim Christian
Tim Christian's Avatar
I have some somewhere I will see if I can find them
Tim Christian is offline   Reply With Quote
Old 02-05-2015, 09:05 PM   #4
Chevyc10572
Does the frame use the same size rivet on the hole frame
Old 02-06-2015, 08:04 AM   #5
CUSTOM/10
CUSTOM/10's Avatar
The frame rivets are 11/32 but are very difficult to find. The next size up is 7/16.
Gary
Gary
72 SWB 4x4
My 72 SWB Build
http://67-72chevytrucks.com/vboard/s...d.php?t=259859
CUSTOM/10 is online now   Reply With Quote
Old 02-06-2015, 09:30 AM   #6
Keith Seymore
Keith Seymore's Avatar
3/8" grade eight bolts were used as the assembly line repair for miss hit or missing rivets.
Is there a reason you want to re-install a rivet rather than a bolt?
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 02-06-2015, 10:32 PM   #7
Chevyc10572
I'm going back to original thats why I want to know what size
Old 02-07-2015, 11:45 AM   #8
Keith Seymore
No problem.
Just wanted to make sure you were aware that a bolt is an acceptable GM authorized repair, in case you could go that way.
K
1979-1986
1986 - 2019
Old 02-07-2015, 02:54 PM   #9
Chevyc10572
So whats the right size
Old 02-07-2015, 03:09 PM   #10
CUSTOM/10
CUSTOM/10's Avatar
11/32 is the original size, but you may not be able to find any. So the next best thing is to step up to 7/16. That's what I did.
Gary
72 SWB 4x4
My 72 SWB Build
Old 02-07-2015, 04:04 PM   #11
bbcmudtruck
Yep, I've replaced most of the rivets in my frame with grade 8 7/16.
bbcmudtruck is offline   Reply With Quote
Old 02-07-2015, 04:28 PM   #12
Fitz
You can find them here:
http://www.rivetsinstock.com/rivets/...id-rivets.html
Fitz is offline   Reply With Quote
Old 02-07-2015, 05:06 PM   #13
Chevyc10572
Do I have to do any drilling
Old 02-07-2015, 05:25 PM   #14
71blksuper4x4
SWB 4x4 Collector
Yes you will have to drill to the 7/16 hole id.
TREVOR
Old 02-07-2015, 07:07 PM   #15
bbcmudtruck
A good bit will need to be used if your replacing a lot of rivets. I've went through two high grade bits, but I've also replaced nearly every rivet with a 7/16 bolt.
Old 02-08-2015, 04:24 AM   #16
Chevyc10572
Are there different lengths I need to know
Old 02-08-2015, 12:19 PM   #17
bbcmudtruck
Which rivets are you replacing? I used a few different lengths in a few different places. I also used a washer on the top and bottom along with a lock washer. That took a little longer bolt in some places. Here's how the order went, bolt, flat washer, frame/cross member, flat washer, lock washer, nut. I think for the most of the cross members I used 1 1/4" to 1 1/2".
Old 02-08-2015, 05:12 PM   #18
Chevyc10572
What length rivets
Old 02-09-2015, 08:05 AM   #19
CUSTOM/10
CUSTOM/10's Avatar
There are different lengths depending on how many layers of steel the rivet has to pass through. I believe it's Big Flats rivets site that has the instructions, maybe other sites do also. I bought like 1-1/2 in rivets and cut them to the proper length using their formula.
Gary
72 SWB 4x4
My 72 SWB Build
Old 02-09-2015, 08:17 AM   #20
CUSTOM/10
CUSTOM/10's Avatar
http://bigflatsrivet.com
Here's a link to Big flats, they have the instructions down at the bottom of the page on the left.
Gary
72 SWB 4x4
My 72 SWB Build
