Axle redrill ideas
I'm using 78 C10 HD brakes on my truck. I have come across a nice set of billet wheels that are ford 5x5.5! I already ordered the Moser rear axles for that bolt pattern for the 12bolt, however anybody got any ideas on how to get the front rotors/hubs done? I don't have the room for adapters, and I was hoping to redrill but not sure if there is enough room. Wondering if anybody knew of a rotor assy that is close enough to work.
Re: Axle redrill ideas
rottenleonard.com sells the drill jigs for around $100
1967 C10 lwb two tone, 305 & rat fink style floor shifted 700r4, 20" steelies 2004 2500HD utility bed aka Brutus |
The correct bolt pattern might be able to be re-drilled on a 5x5 rotor if there's enough material. But.... what about the hub dimensions? If the wheels are hub centric, that will be another obstacle you might need to over come.
Lug centric, talked to Moser today they offer the redrill for $90, I may have a new set off hub/rotors drop shipped to them. For the rear they just send out a set of moser axles with that 5x5.5 pattern. Just have to get the rear chopped 3" both sides and find some rotors and calipers for the new bolt pattern on the rear.
#5 | |
Copy
