02-07-2015, 06:40 AM | #1 |
Fianlly bought it! need to learn a lot!! air ride and rust question
Finally after have looking for months I've take my decison and deicide to bought this e c10addicted 64 from Berlin! The owner bring it to me trough 1200km on a trailer and under the snow!!Amazing guy!!
Now it sit in my garage, I've still not had the possiility to try it well but I love it! Find out some history from the builder to the previous owner in the Usa, nice. Now I think I will need help and I've start reading a lot.. The truck air suspension work good but I've noticed that it raise up and go down very slowly compared to video I've seen of truck and cars that go up and down very fast, it has a viair compressor from whaat I know, what I'll do for have it moving faster? new compressor? bigger diameter hose? I really dont know nothing about this thing and you wont find lot over there.. Another thing is the cooling system ,from what I've seen it heat up very fast, did I need maybe a electric fan? different radiator? Also the start of the engine is a little hard, it take sometimes before stay on regular, it doesnt have choke and has a mechanical fuel pump, any tips? I apologize for the probably stupid answer, just need to learn some basic I think.. and..some pics! |
02-07-2015, 10:28 AM | #2 |
Re: Fianlly bought it! need to learn a lot!! air ride and rust question
fast airbags: both tank pressure and valve size affect speed.
does the system have a gauge to tell you the reserve tank pressure after the viair compressor runs and stops? a 200psi system will operate faster than a 150 psi system because of the higher reserve starting pressure. what kind of valves does the system have? are they electric, do you click an electric switch to operate them? are they manual, do you act directly on the switch? likely the orifice size is what is limiting your speed, either in the valves or sometimes the air line size. if the truck has a 1/4" tube system with manual "paddle" valves, it is considered one of the simplest systems but is also regarded as very slow. if the truck has a 1/2" tube system with very small electric valves, the system speed will still be regarded as slow because the smallest orifice in the system is limiting flow. the entire system must be sized for what you want. so if you the valves and or the airline have small orifices and you upgrade them to larger parts, the reserve tank may not be large enough to provide the volume for lifting, and the compressor may not have the recovery time to allow you to raise and lower the truck more than one time before needing a long recovery time. my truck, as an example, has a 180psi 6 gallon reserve tank and an engine driven compressor from an old ford car air conditioning system. Recovery time (time to fill the tank back up from after the valves fill the airbags) is about 23 seconds. This would take 3-5 minutes for an electric compressor, and 2-3 minutes for two electric compressors. when the tank is completely empty (after sitting a long period), it takes about 55 seconds to fill from 0-psi to 180psi. my valves are large orifice manual valves, the orifice is about 3/8" and they are operated by toggles. the air line is 3/8" in size. It is not as fast as some I have seen but it will still raise the front to 90psi in less than 2 seconds and the rear to 35 psi in under a second, and will drop the truck fast enough to make the frame "clunk" on the pavement. every component in the system is sized for this 3/8" orifice size, so that there is no restriction. If the system had 1/2" orifice valves, you would expect to use 1/2" air line, and the system would be so fast at 180psi operating pressure it would be very difficult to set the ride height without a precise valve control system such as accuair or ridetech e-level. when using large valves, some people use speed controls on the dump outlets to prevent slamming the truck down on the highway when attempting to make a small height adjustment. so figure out what you would like the system to do. the 1/4" manual paddle valve system may not be as fast as you would like, but it does allow very precise adjustment and does not require huge compressor and reserve tank systems. The 1/2" valve and 1/2" line systems are fun for about 30 seconds in my opinion, and are hard to adjust on the highway without danger. in order to play with any system, you will need a recovery tank large enough to fill the air bags multiple times, and a compressor system able to fill that recovery tank quickly. electronic control systems like accuair and e-level will allow precise control of speed and ride height, the only drawbacks are the cost and complexity, the additional sensors must be installed so the system has feedback on the actual height of the suspension. engine heat up: as long as it doesnt overheat, I would say you dont need any additional fans or radiator. a V8 will warm up pretty quickly as a general rule. hard starting: if you have a carburetor, it must be adjusted for the altitude and conditions where you live. if the carburetor has an electric choke, make sure it is closing fully when cold and opening fully when hot. if it just stumbles a bit in cold weather and needs you to stay in the truck while warming up, well, welcome to owning a carburetor truck. it will never perform like a fuel injected vehicle, where you just start it and patiently wait 30 seconds before driving away, a carb engine must be warm and ready to run before driving in cold weather. good luck, I remember seeing the truck here in the past, very nice truck! I actually used this truck as a reference on the rake I wanted for my own!
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 Last edited by joedoh; 02-07-2015 at 10:37 AM. |
02-07-2015, 11:52 AM | #3 |
Great post, and what a beautiful truck! I would make it mechanically sound and not touch a single thing cosmetically
02-07-2015, 12:53 PM | #4 |
Congrats, Great looking truck!
It only has original paint once |
02-07-2015, 04:15 PM | #5 |
Congrats. That truck is one of my personal favorites on this forum.
Name: Rich Current Ride: 1964 C-10 Short Fleetside Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe Past GM Trucks: 1959 GMC short stepside 1968 GMC short stepside-4x4 1973 Chevy short stepside 1989 Chevy short fleetside-reg cab 1993 Chevy short fleetside-Xcab 2002 Chevy short fleetside-Xcab Save the dinosaurs, use synthetic oil. Last edited by Slow Build; 02-08-2015 at 12:46 AM. |
02-07-2015, 04:33 PM | #6 |
Where is Modena???
02-07-2015, 04:51 PM | #7 |
Projects: 65' Chevy C10 swb (rebuilt chassis) 65' Chevy Panel swb 64' Chevy C30 flatbed "above" 80' C30 "beneath") Parts: 66' GMC 2503 & 65' GMC I1500 |
02-07-2015, 05:02 PM | #8 |
Name: Rich Current Ride: 1964 C-10 Short Fleetside Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe Past GM Trucks: 1959 GMC short stepside 1968 GMC short stepside-4x4 1973 Chevy short stepside 1989 Chevy short fleetside-reg cab 1993 Chevy short fleetside-Xcab 2002 Chevy short fleetside-Xcab Save the dinosaurs, use synthetic oil. |
02-07-2015, 11:03 PM | #9 |
Slow Build, your posted pics look amazingly identical (with a Stateside background) to the OP's truck.
02-07-2015, 11:05 PM | #10 |
That's cool! That sweet pick up just travelled from Germany to Italy. I wonder how it got to Germany. Is it really the same pick up as was featured in that article? It does look quite similar.
02-07-2015, 11:20 PM | #11 |
awesome truck. perfect stance
1960 short bed fleetside factory 4x4 1960 panel 454 NV4500 Daily driver 1961 Short Bed BBW Fleetside 5.3 th400 swap in process |
02-07-2015, 11:50 PM | #12 |
auguri!!!
02-08-2015, 12:03 AM | #13 |
same truck...the patina on the hood and scrape on the front bumper are identical. Hey slow build...who did you sell it to?
02-08-2015, 12:41 AM | #14 |
Wasn't mine. c10addict owned it. Here is his ad that he had on the forum when he was selling the truck back in 2009.
http://67-72chevytrucks.com/vboard/c...urgh-pa&cat=11
02-08-2015, 12:45 AM | #15 |
Wow! 6 years later its now Italian
02-08-2015, 02:14 AM | #16 |
Hey hey!! Yes all that is my old truck! So cool to see it go from Germany to Italy espically because I am German / Italian! Lol ... The air system is slow because it's 1/4" line and manual valves .. The truck needs bigger line and Accuair or if you want to keep manual valves I love the Little Larrys valves! As far as the other issues , they were not in the past so not sure what to tell you.. That was me driving in the pics at Columbus Goodguys... That was a great truck with one of the first few dropmembers ever released !! Good luck with it and take good care of her!! I wish I would have never of sold it !!
68 C10 Shorty TPI,Bagged, and all the good stuff. Classic trucks feature June 06, On the cover of Jegs Christmas Catalog 08 67 C10 Shorty Shop truck project Bagged and Z'd under destruction and getting nowhere fast. 64 C10 Shop Truck/Daily driver, Bagged, Dropmember, SOLD!!!! Gone but not forgotten.. 54 GMC under the knife getting a S10 chassis swap and bagged. See my build thread... 07 GMC Sierra 5/7 drop, 22's and 24's Air ride on my mind.. http://67-72chevytrucks.com/vboard/s...d.php?t=339340 See pics of my trucks in my profile Last edited by c10addict; 02-08-2015 at 02:19 AM. Reason: Added to |
02-08-2015, 08:53 AM | #17 |
@c10addict That was the first 60-66 c10 that made me drop everything I was doing and take notice. I was always a 67-72 guy. I must have looked at your truck 30 times @ Columbus GG.
Bruce 1964 C10 SWB #Junk 1979 C10 utility #cargopants (sold) 1971 GMC Sprint (sold) 1974 GMC Grande Sierra (sold) |
02-10-2015, 06:23 AM | #18 | |
@joedoh, amazing post!!! even if I've just understand a quarter of all the things I've read! I really need to learn more on airbags!! @c10addict I'll take care of it dont worry, I'm really in love with this truck! What I need to do for stay with those manual valve, that I love and make it a bit faster? Things I think I would like to do is some for hood hinge, hood is so heavy and hinge really work bad..will a new original one help? this one dont has any spring.. and there's a really bad rust on the front hood patch panel lower , that I've seen is possible to order the spare parts.. and I've some on the up of the windshiled, in the interior..but I think repaior that will mean almost take out the cab and do a very big work.. |
02-10-2015, 09:08 AM | #19 |
Hotrodv: Beautiful truck!
If your hood does not currently have springs, then that is your problem. The hood hinges have tension on them via the springs that not only hold the hood open, but aide you in lifting it. Rust repair: Depending on where your rust is, you can typically do most repairs with the cab on the frame. Some repairs may be a bit more difficult, like the cab mounts, but most are possible without removing the cab.
64 LWB to SWB Step build. Daily driven! http://67-72chevytrucks.com/vboard/s...d.php?t=647168 |
