Old 02-09-2015, 07:03 PM   #1
Longhorn 70
Longhorn 70's Avatar
70 bench seat, is there a folder available?
I have the stock seat in my 70. I also have a reupholster cover ready to go on. Is there a folding seat available that the cover will fit? Is it bad to change the seat on a truck that isn't 100% original? Am I asking too much for a folder that the cover made for stock seat will fit? Is there a way to convert the fixed seat to a folder?
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11.
1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar
And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9
Longhorn 70 is offline   Reply With Quote
Old 02-09-2015, 07:19 PM   #2
Mike C
Mike C's Avatar
Re: 70 bench seat, is there a folder available?
I think the 3 door Suburban middle seat is the exact same size/shape but is a folder.
You might be able to tweak the foam on a '73 up truck to fit your upholstery.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 02-09-2015, 07:21 PM   #3
EARNHARDT#3
EARNHARDT#3's Avatar
'67 folds. Not sure if the cover fits though.
EARNHARDT#3 is offline   Reply With Quote
Old 02-09-2015, 07:27 PM   #4
Longhorn 70
OHHH I wonder if I could just steal the hinges off of the Burb model seat.
Old 02-09-2015, 08:32 PM   #5
65standard
65standard's Avatar
My seat is a folder.
Tony Nicholas @ Midwest Metal Masters
1953 Chevy 3100 392 Hemi w/727 & 9” Ford
1985 Chevy C/10 6.0L 4L80 373 locker
65standard is offline   Reply With Quote
Old 02-09-2015, 09:09 PM   #6
Dakotachevy68
65standard can you post picture of the brackets to the floor? Also is that an original seat height?
Dakotachevy68 is offline   Reply With Quote
Old 02-09-2015, 10:01 PM   #7
65standard
65standard's Avatar
It is bolted in the original holes.
Old 02-09-2015, 10:04 PM   #8
65standard
65standard's Avatar
And my floor.
Old 02-10-2015, 09:32 AM   #9
Longhorn 70
65 standard, mine has different stands than that. Were there different seats for different option packages? Mine is a Custom/20. Also I don't have the plastic cover on the bracket that connects the base to the backrest.
Old 02-10-2015, 12:39 PM   #10
67ChevyRedneck
67ChevyRedneck's Avatar
65 Standard, your seat is out of a 73-87 truck.
In 1968 the federal government came out with a lot of new safety requirements. One of which was turn signals. Another was that seats needed to either be fixed or have a latch so they didn't fly forward in an accident. GM got around this on the trucks by making the seat "fixed" and not having to spend money on new parts/tooling, etc, especially since nothing really fit behind the seat because of the fuel tank. When the fuel tank was moved to under the truck in 1973 and the seat was redesigned, GM added the safety latches to the bench seats for those model trucks so you could flip the seat forward and store stuff behind there.
Passenger Cars (Effective 1-1-68); Shall meet requirements for instrument panels, seat backs, sun visors, and arm rests. interior compartment doors are required to remain closed during a crash.
My 67 had the flip forward seat, wish I had kept it as my tank is no longer under the bed!. The majority of seat covers available for these trucks are the 68-72 styles that wrap over the side of the arm so you'd have to cut that part off? Not sure if you can buy 67 covers, never really looked into it.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 02-10-2015, 12:48 PM   #11
67ChevyRedneck
There isn't a "hinge." The "hinge" on the bench seat is part of the seatback.
I recently redid my 1972 style seat. If I remember right, on the 67 seats GM just used the lower hole as the pivot hole. The upper hole/screw was added in 68+ to "lock" the seat in place. You can also see the extra material that will cover the arm:
The material that folds over to hide the arm. On the 67's the arm is exposed.
Jesse James
Project "On a Dime"
Old 02-10-2015, 01:07 PM   #12
AirSpeed
AirSpeed's Avatar
I wonder if you could just remove the upper bolt and make the seat fold?
AirSpeed is offline   Reply With Quote
Old 02-10-2015, 01:37 PM   #13
michael bustamante
michael bustamante's Avatar
i have my 67 bench seat and its in pretty good condition. not even the foam is torn. it just needs a cover. ill have to look at it good and see the differences. i was hoping to order a cover but i cant find a 67 specific anywhere.
1967custom
michael bustamante is offline   Reply With Quote
Old 02-10-2015, 02:19 PM   #14
67ChevyRedneck
I believe you can, but you won't have the "safety latch" and there won't be anything to stop the seat from going too far back.
Found this pic... don't know if an upholstery shop made the cover or if someone does offer a 67 style cover. You can also see there is a "stop" behind the arm to keep the seat from going too far back (visible right above the seat belt).
Jesse James
Project "On a Dime"
Old 02-10-2015, 05:33 PM   #15
65standard
65standard's Avatar
65 Standard, your seat is out of a 73-87 truck.....
You might be right, but I just went and looked at an original 1977 C10 and the seat mounts are very different the way they bolt to the floor and it has the seat belts going through a slots in the lower cushion. My plaid seat has the same track mounts as the original 1970 seat that came with the truck and it was a direct bolt-in.
The guy I bought the seat from said it was for a 1967-1972 C10. I only got it because my original seat needs new uphostrey, foam, and spring repairs. If this seat is completely wrong for my truck, I will just restore my original one.
