Old 02-10-2015, 10:40 PM   #701
nlped
nlped's Avatar
Re: Project: Shiro
Originally Posted by Bucks68 View Post
Replacement dash for Shiro??
Attachment 1361973
Why not an A/C dash?
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 02-10-2015, 11:47 PM   #702
C10_ustacould
A day late and $1 short...
C10_ustacould's Avatar
Re: Project: Shiro
I don't like the factory side vents, I'll use smaller vintage air vents similar the ones I used on the green stepper.
Buck
Instagram: C10_ustacould
1963 SWB Fleet Side 528 Desert Beige
Milly
1967 SWB Step Side 506 Medium Blue
The Old Girl
1968 SWB Fleet Side 503 Light Green
Ellie SOLD
1965 SWB Fleet Side 507 Light Blue
Prescription Strength SOLD
1971 SWB Fleet Side 521 White
Shiro SOLD
1968 SWB Step Side 503 Light Green
My Old Farm Truck SOLD
C10_ustacould is offline   Reply With Quote
Old 02-10-2015, 11:49 PM   #703
cericd
cericd's Avatar
Re: Project: Shiro
Why don't you like the factory side vents? Too bulky?
Chris
My 1970 SWB C/10 - https://67-72chevytrucks.com/vboard/...d.php?t=534872
cericd is offline   Reply With Quote
Old 02-10-2015, 11:59 PM   #704
C10_ustacould
Re: Project: Shiro
Exactly, the Vintage Air and Billet Specialties vents are smaller and blend very well with the factory styling in my opinion.
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 02-11-2015, 07:25 AM   #705
nlped
nlped's Avatar
Re: Project: Shiro
Gotcha! I knew you'd have a good reason.
Carter
Old 02-11-2015, 11:12 AM   #706
C10_ustacould
Re: Project: Shiro
I don't know about it being a good reason but it makes sense in my OCD soaked brain.
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 02-11-2015, 11:44 AM   #707
nlped
nlped's Avatar
Re: Project: Shiro
Carter
Old 02-17-2015, 11:03 PM   #708
C10_ustacould
Re: Project: Shiro
OKay... silly question time. I have the cab back on the frame and torqued down and I want to make sure I have a handle on this sheet metal repair process. I'm going to leave the doors on for the moment and start by drilling out the spot rivets in the outer rocker. Once they are out of the way I will remove the inner rocker and however much of the floor I want to replace as well as the lower portion of the kick panels. Once I am to this point I just fit my panels to what I have cut out and work it in reverse order. I know this is a simplistic view, but it will help bring out any special advice any of you may have. So what do you think, am I on the right track. I hope I can muster the testicular fortitude to knock this out myself, if not maybe I give the guys at Nsane Hot Rodz a call!
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 02-17-2015, 11:46 PM   #709
sduckworth13
sduckworth13's Avatar
Re: Project: Shiro
Buck here are some pictures from my first cab I did. Measure, measure, measure
Scott
sduckworth13 is offline   Reply With Quote
Old 02-17-2015, 11:51 PM   #710
sduckworth13
Re: Project: Shiro
Sorry about the individual pictures, I'm on my phone.
Scott
Old 02-17-2015, 11:53 PM   #711
sduckworth13
Re: Project: Shiro
Welded in.
Scott
Old 02-17-2015, 11:57 PM   #712
sduckworth13
Re: Project: Shiro
Make sure you measure from the floor to the lip of the inner rocker where the outer rocker sits in. Then weld your inner rocker in, then your kick panel, then the lower door pillar then your outer rocker. Buck, I probably test fit my door 50x before I got the gap of the outer rocker where I wanted it before I finally welded it in.
Scott
Old 02-17-2015, 11:59 PM   #713
sduckworth13
Re: Project: Shiro
Here is the final pic.
Scott
Old 02-18-2015, 07:51 AM   #714
C10_ustacould
Re: Project: Shiro
Thanks for the visuals Scott!
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 02-18-2015, 09:30 AM   #715
Hart_Rod
Hart_Rod's Avatar
Re: Project: Shiro
So there you go, I expect one side to be done by the weekend.....
Hart_Rod is offline   Reply With Quote
Old 02-18-2015, 10:34 AM   #716
C10_ustacould
Re: Project: Shiro
Sure, that means we should count you in for dinner the rest of the week. The least I could do is feed you if you are going to be here every night.
The one thing I just though about was the cab corner, where does that fit in the timeline? It looks like it tucks under the aft end of the outer rocker so I'm guessing it can be laid out and cut anytime after the outer rocker and go back in after the inner rocker is installed?
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 02-18-2015, 10:47 AM   #717
sduckworth13
Re: Project: Shiro
Good luck Buck, your welds looked great on the firewall panel so I think your way ahead of the curve and won't have any issues. Just measure a lot and you'll be good. I'm about to start tearing into my new cab and will probably be doing similar repairs again. I won't know anything till I get the outer rocker off, its pretty cold here so I'm going to put it off until it warms up enough to open the garage doors.
Scott
Old 02-18-2015, 10:14 PM   #718
GAc10boy
GAc10boy's Avatar
Re: Project: Shiro
Been going back through and reading your build, Buck. You're making killer progress! I am a bit confused on one thing: did you decide to switch to bags or keep the coilovers? I'm sure I missed it but thought I'd just ask.
- Robbie
UNITED BY TRUCKS - classic truck video content
YouTube: www.youtube.com/c/unitedbytrucks
Instagram: @united_by_trucks
Paw Paw '68 508 Dark Blue Custom C10
Teddy '68 GMC SWB 503 Light Green LS Build
Mississippi Mud '75 Skyline Blue Patina SBC Build
GAc10boy is offline   Reply With Quote
Old 02-27-2015, 11:02 AM   #719
C10_ustacould
Re: Project: Shiro
Keeping the coilovers.
Ordered ebfabman's sheet metal repair videos to aid in the rust repair effort. Hopefully the rust repair goes well and I can get it blown apart for paint and powdercoat soon.
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 03-01-2015, 11:06 PM   #720
C10_ustacould
Re: Project: Shiro
Fooled around in the shop this afternoon...
Actually started the other day, I wanted to see what was lurking behind the cab corners so I cut a hole in the driver's side and pulled out a bunch of what I guess is seam sealer and a hairball. Yuk!
Then I wanted to see how the spot weld bit worked... Worked too well on the top one!
Then I figured I would cut a hole in the rocker and take a look and see how much of the inner rocker was corroded...
The area where the outer laps over the inner rocker was pretty corroded and the seal retailer lip was rotted away, so why not remove that too, right? A lot of light coming through there.
After drilling out a bunch of spot welds the outer rocker is off! Not sure at this point if I am going to change the inner rocker or just patch it. We'll have to wait and see.
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 03-01-2015, 11:15 PM   #721
C10_ustacould
Re: Project: Shiro
One spot that has me freaking out is the lower pillar, its pretty hammered.
This thing is swiss cheese...
... more cheese
I was trying to abracadabra this thing on there but none of the spells I knew worked , I guess I'll have to do it with actual work.
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 03-02-2015, 12:15 AM   #722
sduckworth13
Re: Project: Shiro
Buck trade out that door pillar for a Tabco. You'll be surprised at how well it fits.
Scott
Old 03-02-2015, 12:16 AM   #723
sduckworth13
Re: Project: Shiro
You can make that work, it will take a little bit of work though.
Scott
Old 03-02-2015, 12:41 AM   #724
C10_ustacould
Re: Project: Shiro
Who sells tabco pieces?
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 03-02-2015, 12:48 AM   #725
sduckworth13
Re: Project: Shiro
Here is a link to there website. https://tabcoparts.com
I couldn't get the online order to go through so I just called them. The online order system is new so it probably needs the kinks worked out.
Scott
