Old 02-10-2015, 10:57 AM   #1
of13swc
Rubber fuel line question?
Is it ok to run rubber fuel line from rear mounted tank to fuel pump?
of13swc is offline   Reply With Quote
Old 02-10-2015, 11:30 AM   #2
TopFuel1966
TopFuel1966's Avatar
Re: Rubber fuel line question?
I suppose you could but I wouldn't. Too easily damaged by potential road hazards. If you don't want to run hard line use braided steel line with A/N fittings and adapters. That's what I did.
TopFuel1966 is offline   Reply With Quote
Old 02-10-2015, 01:22 PM   #3
of13swc
What adaptors did you use? Something like this?
Fragola Performance Systems EFI Adapter Fittings 491989-BL
Old 02-10-2015, 02:00 PM   #4
4shongo
Just buy a length of hard fuel line for the main run next to your frame and then make your connections to the tank and pump with the rubber fuel line. Easy day!
4shongo is offline   Reply With Quote
Old 02-10-2015, 02:29 PM   #5
frankslagoon
I use brake line. they come in different lengths and they have connection on each end. the 5/16 dia. are enough for most engines.
frankslagoon is offline   Reply With Quote
Old 02-10-2015, 08:25 PM   #6
of13swc
OK so I decided to use SS braided. Now my problem it how do I connect the AN fitting to my fuel sending unit that has tube connection?
Old 02-10-2015, 09:03 PM   #7
DPowers
One foot in front of the other
DPowers's Avatar
Check a local speed shop, Jeg's or Summit.
DPowers is offline   Reply With Quote
Old 02-10-2015, 10:43 PM   #8
forestb
forestb's Avatar
I had the same problem. I ended up having to get a new fuel pump.
forestb is offline   Reply With Quote
Old 02-11-2015, 09:07 AM   #9
65chevysub
65chevysub's Avatar
I used to have a 73 Dodge D200 Pickup and installed a plastic 40 gallon van tank in the frame to replace the cab tank, and ran rubber line all the way to the front inside the rails, and it held. I know it wasn't the right way to do it, but it worked for a tight budget. Do it the right way as others here suggest to avoid any "issues"
65chevysub is offline   Reply With Quote
