02-05-2015, 08:25 PM | #1 |
Old member
Electric seats/heated
Ok I started on the truck last weekend while I was off and got the new carpet in along with the gear shifter. I had to build the enclosure around the gear shifter also since the old one wasn't level.
I started today on drivers side so I hope to drive it this weekend hopefully. The new fuse panel did fine after hooking up the electric/heated seats. I got the sub box in and corner drivers side speaker enclosure installed. I need to decide if I want to paint them are cover them with carpet. I also have to fill in behind them with insulation. I have the drivers seat in and wired also.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
02-06-2015, 04:38 PM | #2 |
78K & 79C Jimmys
Re: Electric seats/heated
cool I just got some too,what kind are those?
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
02-06-2015, 07:21 PM | #3 |
Old member
Are you speaking of the seat's? They are 1999 Tahoe front seats. All the controls are on the door side of each seat. Both seats work great now. The heater in the drivers side I never got to working so I bought aftermarket heating pads for both seats backs and bottoms the factory was just bottoms.
I took and cut the opening just enough to insert the switch in the factory spot and I wired everything to the factory wiring harness. I even wired the heater through the seat belts so if the person forgets to turn off the heater when they unbuckle it shuts off. I had them in for about 2 months but I found a center console to install and it hit the S-10 shifter so I had to pull everything back out to get the new carpet in after realizing the shifter left a great big hole in the carpet!
02-10-2015, 05:39 PM | #4 | |
78K & 79C Jimmys
and keeping it all GM is nice,I got a set of dodge ones free to play with
02-10-2015, 09:20 PM | #5 |
Old member
Thanks I try!
02-10-2015, 11:18 PM | #6 |
where did you find the new covers for the gm seats?
I have a 99 that needs new covers, and those look good. Jim |
02-11-2015, 03:25 PM | #7 | |
Old member
Can't believe they aren't leather covers. I bought them off this site. http://www.autoanything.com/seat-cov...A4353A0A0.aspx
